Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Sep 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer Duet Control Locked, cannot do anythink, tried the advice but nothing when I push on ON & Cancell I see three bars --- in red, thats all,
Dan Webster
Level 3:
  • Whirlpool Master 8,221 Answers
  • Posted on Sep 05, 2011
Dan Webster
Whirlpool Master
Level 3:
Answers
8221
Questions
5
Helped
2378961
Points
25840
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Hi, After just finished washing one load, on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
The problem is, there is a red lite on thaty says controls locked and it won't go off. I have tried unplugging it but the lite comes back on when I plug the washer in.
you will need to change the interface control if that is the case or if you did not try it yet there is a button on the bottom right hand corner of your control panel it says to hold down for three seconds to unlock control.
Hi I have a whirlpool front load washer model number ghw9100lw my problem is that i am getting a f05 code i have changed the temp sensor and i am getting the same code i have unplugged the washer now when...
Check and replace
- Flowmeter.
- Water inlet valve
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
3helpful
My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
36helpful
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
My washer is locked. I have unpluged it, pushed the control button and nothing works. I have losted my manual.
If you have a whirlpool duet, press the END OF CYCLE button (located at the far right side of the control pannel)and hold for 3 seconds. This should unlock the control pannel. It's written in tiny writing under that button as well.
3helpful
2answers
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
Whirlpool Duet Dryer
Greetings Inakao,
What you need to do is press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
CONTROL LOCKED
I you push and hold the END OF CYCLE SIGNAL button on the left of the control panel for three seconds, it should unlock the control panel.
14helpful
3answers
WHirlpool duet washer is stuck on "controls locked"
we ended up holding the drain/spin button for a period of 15 or so seconds and the issue resolved.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
