SOURCE: HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
SOURCE: hitachi ultrascan HD tv 43 inch
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
SOURCE: How do I make my tv hd
I IF YOU CAN SEE IF YOU CAN GET ATT U-VERSE THEY WILL SET YOU UP FOR CABLE IN HD AND THEY SUPPLE THE HDMI CORDS OR THE CORD THAT YOU NEED FOR TRUE HDTV
SOURCE: is my Hitachi 61uwx10b ultravision hd ready
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
SOURCE: Hitachi 53FDX20B -- HD tuner?
hi, hd ready means the tv is capable of re-producing the hd picture from a cable or satellite co. call your local cable/sat people they can advise you which channels are which in your area, video-tek
