Question about Russell Hobbs Blenders
SOURCE: Replacement glass jug?
I will buy the blade set from you? I will return....
Posted on Feb 22, 2008
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
Posted on Jan 21, 2009
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
SOURCE: Broken glass jug - Sunbeam blender PB7600
I have one, marlene 0409465707
Posted on Feb 27, 2010
Mar 29, 2018 | Blenders
Jan 24, 2016 | Russell Hobbs Blenders
Jul 12, 2014 | Blenders
Dec 05, 2013 | Russell Hobbs 18276 Allure 1.5l Jug...
Sep 20, 2010 | Russell Hobbs 3902US Work Top Blender
Feb 10, 2010 | Russell Hobbs Blenders
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
Mar 18, 2009 | Russell Hobbs RH-HB3 Handheld Blender
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
57 people viewed this question
