SOURCE: Beko D533 cooker only half working
Is the cooker a new one? I fit is then it does sound like an internal wiring problem, in which case you should contact the supplier. Make sure it is wired correctly from your circuit breaker first, There should be a diagram showing the connections.
Hope this helps.
Please leave feedback.
SOURCE: beko dvc6531 cooker
i can send u a copy of user manual if you need one you have to hold the first two buttons in then move time with up or down please email me if you need more info [email protected]
SOURCE: beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
SOURCE: have a new electric cooker but the oven and 1 of
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
SOURCE: Beko dv555w electric cooker.Oven and
Hi
check that the cook mode is set to MANUAL, as if its on AUTO it will not come on.
