From 2006 to 2010, the Sonata's 3rd brake lamp requires the rear package deck be removed to access that bulb.
1. Remove the rear passenger seat bottom (remove two12mm bolts between the seat back and the seat bottom - tilt the seat back forward to locate these bolts).
a. Press the two bottom front edge tabs to release the front of the seat bottom from the floor.
b. Remove seat bottom & set aside w/two 12mm bolts
c. Tilt both seat backs downward
2. Remove the left & right hand shoulder cushions (12 mm bolt at the bottom of each cushion)
a. Remove seat belt from shoulder cushion guide at the top of the cushion
b. Lift up and forward on shoulder cushions to remove them (if equipped with side airbags, disconnect wire harness connector).
c. Set shoulder cushions aside w/two 12mm bolts
3. Using a small flathead screwdriver, pop out the 'SRS' button cover from the C pillar panels on the left & right hand side to access either the phillips head screws, 10mm bolts, or #30 Torque Screws
a. Remove screws and set aside
b. Using a standard flathead screwdriver, pop out the C pillar panels on both sides (clips hold these panels in place)
c. Set these panels aside after removal w/screws/bolts
4. Trunk Access-way panels are held in place by phillips head screws (two at the bottom (left and right hand sides) and 4 to 5 at the top .
a. Remove left and right hand panels and set aside w/screws.
5. Rear package deck held in place with two plastic clips (white, yellow or pink)
a. lie on your back inside the trunk (trunk lid open to allow for more light). Looking through access hole find 3rd brake light wire harness connector & disconnect.
b. locate package deck clips, one on the left and another on the right on the underside of the pckage deck
c. Squeeze clips to push them out - package deck will come loose
d. Remove package deck & remove 3rd brake lamp bulb socket (turn counter clockwise to remove). Replace bulb & reassemble in reverse order.
