Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
SOURCE: Transfer from Laptop to 250gb WD
you need to format the dirve to NTFS or FAT32
current format has a file size limit
thanks for rating
Posted on Jan 09, 2008
SOURCE: Cant See Data On WD External (500GB)
dear,dont take tention,if data is deleted accidently i can recover total data your using some software.
so first you try
1-remove some data from Hard disk
2-may be virus occured or attach with files.
yes you can easily recover the delete files.
Posted on Apr 12, 2009
SOURCE: WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
Posted on Jul 25, 2009
SOURCE: Accidentally disconnected external HD while moving files
have the files been deleted from the laptop? if not i would simply do a fresh format on the external and re migrate data. if they are then you can get software such as undelete or recover my files to restore your deleted data off of your laptop drive.
Posted on Dec 09, 2009
SOURCE: Currently my 500 GB WD External Drive has 353GB as
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Posted on Feb 05, 2010
