Hi.
Turn off the touchpad
Most HP
notebooks come with an on/off button near the touchpad. If you do not
wish to use the touchpad at this time, press this button. Press it again
when you wish to use this accessory again.
If the notebook
does not have an on/off button for the touchpad, touch and hold the
top-left corner of the touchpad for approximately 5 seconds to disable
it and do this again to activate it. When the touchpad is disabled, a
small light will illuminate on the touchpad and an icon will appear
briefly of the touchpad with a line through it. When the touchpad is
activated, a small light will turn off on the touchpad and an icon will
appear briefly of the touchpad.
Alternatively, if the notebook does not have an on/off button for the touchpad, and you wish to turn the touchpad off, open the Mouse Properties window, select the Device Settings tab, and click the Disable button. You may re-enable the touchpad from here at any point.
Regards.
SOURCE: my touchpad has locked on my ProBook 4720s. How do
Simply tap twice on the orange light and your pad will be working again,
this is basically a lock like the HP had in earlier which was made enable/disable by Fn+F7 key,
As a new advancement its a lock and also indicator, when you see orange light it means that touchpad is locked, for unlocking simply tap twice on the orange light on touchpad, and it will start working again
Regards,
Bilal
SOURCE: how to unlock touchpad of hp probook 4520s
when you open a touchpad setting application you have to enable(check) radio buttons.
SOURCE: how to unlock touchpad of hp probook 4520s laptop
Touchpad zone is on upper left of the touchpad: Turning the TouchPad on and off The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
the indicator is on the top left side of TouchPad zone.
Good Luck
Thanks, Joe
