You likely have either a folded cold inlet hose (squashed) or self plumbing tap that is rusted in the cutter so slow filling or a blocked mesh filter in the cold hose connection on the back of the machine, try all three and you should have the answer.
Testimonial: "Thanks!!"
What i believe the problem is,is that the solonoid that opens the cold water side of the water inlet valve is very weak and hardly opening the valve on the cold side...and the water inlet valve needs to be replaced.
Firstly though before replacing the valve,turn off the cold water tap,remove teh hose from the back of the water inlet valve and check for sediment in the filter screen that is blocking the water from coming into the washer...if you dont see much sediment in the filter screen the water valve will indeed be the problem
The part number for that water valve is 285805 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
repairclinic.com
apwagner.com
This youtube video will show you how to replace that water valve http://www.youtube.com/watch?v=Fk4puRv3Vk8
GENE
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
