SOURCE: My Canon PIXMA MP240 all-in-one
I had the same issue!! I called up Canon Australia on 13 13 83.
The gentleman explained that even thought it was called Print Spooler, it was my laptop.
Start Menu > Run > services.msc
Long list of items > scroll down to Print Spooler
STARTUP TYPE SHOULD BE "AUTOMATIC"
AND SERVICE STATUS SHOULD BE "STARTED"
if it's not, click "Start" > then Apply
no need to reboot - try installing the drivers now.
Good luck! If this doesn't work, call Canon tech support in your country :)
Cheers!
Kayo
SOURCE: Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
SOURCE: lost my driver pixma ip1880
Here is the link ,choose your operating system and language:
http://software.canon-europe.com/products/0010455.asp
SOURCE: Cannot install my Cannon mp 210 printer
Hi, the spooler service is usually set to start automatically when the PC starts up. It sounds as if this may have been changed.
To check this right click on "My Computer" & select "Manage" (4th one down), at the bottom of the list you will see "Services & Applications" - if you click on the + next to it you will see some more options, 1 of which is services.
Click on services & the right hand pain will list all services installed on your machine, it should be in alphabetical order so work down to the "P's" & find "Print Spooler", under startup type it should say automatic if it says anything like Manual or Disabled just double click it & on the window that appears change the setting to automatic using the dropdown box, click on start to start the service & you should be flying!
Let me know how you get on.
SOURCE: PIXMA iP1800 InkJet Photo Printer: driver for ip1880...
Select the driver according to the Operating System you have:
http://support-in.canon-asia.com/P/search?category=Inkjet+Printers&series=PIXMA&model=PIXMA+iP1880&menu=download&filter=0
OR
Visit: http://www.canon.com/
Hope this was helpful.
