Hayward SAND FILTER, PRO SERIES Logo
Posted on Sep 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know what all the settings are like bacwash filter on the valve system
Anonymous
Level 2:
Sergeant:
  • Expert 368 Answers
  • Posted on Sep 06, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
368
Questions
Helped
134839
Points
582
FILTER is the valve position when the system is in the normal filtering mode.
When you backwash the filter you first need to turn off the pump, place in BACKWASH position, and run the motor for 45 seconds (or until the backwash water is clear). Turn off pump and run in the FILTER position for 15 seconds. Repeat twice more.
The RINSE position is to clear any dirt in initial start-up cleaning, plus resetting filter bed after backwashing.
The WASTE
position is for vacuuming directly to waste, lowering pool level, or draining the pool.
The CLOSED position is for shutting off all flow through the valve.
The RECIRCULATE position allows water to flow from the pump through the valve and directly to the pool.
You will probably only to use the FILTER, BACKWASH and maybe the RINSE valve position. The RINSE position is not as important as indicated by the fact that many backwash valves don't have a RINSE position.
I hope this helps.
  • elle
    elle Oct 20, 2015
    I need to know where the settings are mine arent visible
I OWN APEUGOT307 1.6 HDI.REPLACED HEAD. ENGINE TURNS BUT WILL NOT START.NEED TO KNOW WHAT THE PROBLEM CAN BE.
Did the head come with camshaft pre fitted? Have the valve to camshaft clearance been set. is the valve timing correct? is the injector pump timing correct. have the fuel filters been changed and all the air bled out of the system? do a compression test to check for worn piston rings or damage.
To adjust hotter
Your shower has been installed for a while and you are noticing the dial must be turned further and further to the hotter settings to get a normal shower - In this case the filter on the hot inlet is getting clogged with debris. Refer to the cleaning instructions in the manual that came with your shower, or contact Hansgrohe USA by calling 800-334-0455 for the documents.
If your installation is brand new or old, debris on the filter is the number one cause of this problem. You can test it by noticing if there is a drop in pressure when you dial to a hot setting as opposed to the cold setting. The drop in pressure indicates dirt on the filter where water has a tougher time getting through.
Filters on a shower valve may seem strange to US consumers. Your old two handle valve system woul run for years without needing servicing. Now you have filters to deal with. These filters, like any filter need to be cleaned periodically and the frequency depends on the quality of your water supply system.
The real benifit, is that the filters protect your smart valve and the shower head from malfunctioning due to debris.
How do i change the sand in the filter? I am getting sand in my pool.
You will simply remove the old sand from your pool filter and follow the instructions from your users manual like you are adding sand for the first time. In case you don't have it, I am going to paraphrase it for you below.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
IMPORTANT: To prevent unnecessary strain on piping system and valving, always shut off pump before switching Filter Control Valve positions.
The correct amout of sand can be determined with this link: http://www.backyardcitypools.com/pool-filters/Filter-Sand-Requirements.htm
2. Set your controls to the backwash position.
3. Prime and start pump according to pump instructions. (be sure all suction and return lines are open), allowing the filter tank to fill with water.
4. Once water flow is steady out the waste line, run the pump
for at least 2 minutes. This initial backwashing of the filter is recommended to remove any impurities or fine sand particles in the sand media.
5. Turn pump off and set valve to RINSE position. Start pump and operate until water in sight glass is clear—about 1/2 to 1 minute. Turn pump off, set valve to FILTER position and restart pump. Your filter is now operating in the normal filter mode, filtering particles from the pool water.
6. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten connections, bolts, nuts, as required.
7. Set your filter to the "filter" position.
Need to know how to backwash the pool filter
Depends ...
There are two primary valve styles ... a "multi-port" and "push-pull". Never change a valve setting with the pump running.
Multiport has a handle that goes around in a circle (only move it clock-wise). You should go to your pool place to identify this kind of valve and get new lables. Push-pull goes up and down. Up is filter - Down is back wash.
If you will study your system, some things will become evident to you .
Your pump pulls water from the pool through the pump ... out of the pump into the filter. Through the filter, back to the pool. You might be heating the water (would be after the filter) and you may be adding sanitiser (after the heater). One suction - two discharges (oh, the other discharge is to waste.).
Recap ... water out of the pool into the pump - out of the pump throuth the control valve to the filter - out of the filter to the heater then to the sanitiser then back to the pool.
Any help?
Thanks for your interest in FixYa.com
BTW ... I am a volunteer question catcher at FixYa.com. At my job, among other things, I am a Certified Pool Operator (CPO), certified by the National Swimming Pool Foundation.
May 14, 2010 • Pool & Spa
Send pictures of the valve assembly to [email protected] and we will try and assist you with your need.
Mar 23, 2010 • Pool & Spa
Hi, went through the process of using sand filter cleanser & degreaser , the glass bottle shows clear water , I know that cannot be possible ,It actually has never showed real dirty water before either...
Sounds like you may have a bad spider gasket in your multiport valve or possibly a weak spring. Do you ever notice water coming out of the backwash while your system is set to filter? Another possibility is your screen on the air relief tube inside the filter is not in place, this will allow debris back into the pool but not alot, most if it would get filtered. Also, make sure your multiport valve is installed correctly and is set to the proper mode. There is a recirculate mode that will allow everything to bypass the filter. The label may even be incorrect.
Using a swimming pool filter system to 'vacuum' the pool floor
i am assumming that you have a sand filter,to clean your filter, 1st put it on backwash and watch the little glass bowl till it run clear,45 sec. or so then turn off power, turn valve to rinse, turn power on. watch little bowl till it runs runs clear 30 sec. or so.to vaccam turn handle to waste turn power on. hope this helps
1helpful
Pressure at 15 psi after backwashing
No that is normal pressure, when the pressure rises more than 10 psi over that in a 24 hour time, you should backwash the filter. Hope this helps
Jul 13, 2009 • Home
Pentair filter
I am sure that you already have an answer to this, but IF you can not read the valve label sticker, call the Pentair Customer Support 1-800 number. They will send you out a new label, free of charge.
For referrence, the waste position is ALWAYS over the waste port on the valve.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
