A typical reason the thermal cutoff would go out so quickly is because of a poor airflow so the heat is being built up in the dryer instead of being vented out.
What to check is for a blocked/restricted vent,lint built up in the blower housing that is restricting the airflow& or a broken blower wheel that isn't moving the air from the dryer.
GENE
In my case, I have a different model (Fisher-Paykel) but my thermal cutout was tripping due to the lint filter being half clogged with fine grit - likely the high mineral content of our city water. To get to the filter, I had to remove the screw at the bottom of the white ring that surrounds the lint bucket, and then insert my screwdriver into the screw slot to get the leverage needed to rotate the white ring clockwise about an inch, which releases the tabs holding it in place.
