SOURCE: 2005 Subaru Outback XT - Real Tail light- bulb replacement
1. Open the rear hatch, and look down towards the bumper, in the direction of the tail light bulb needing replacement.
2. You should see the dark colored plastic trim piece, which is held in place by two small plastic body style philips head screws.
3. These wil only 'loosen' a little bit, you will need to slip a fingernail or some other slim item, underneath the heads of each of the screws, and pull back on them firmly by grasping the body of the screw, not the head (which is flimsy, and can crush if squeezed).
3. remove the plastic trim piece - it can be achieved by lifting out and towards you - set aside.
4. Using a 10mm socket or wrench, unscrew the upper and lower bolts holding the taillight assembly in place.
5. the taillight assembly is now loose - it can pulled rearwards, and will slide off of the small guide slots holding it in place.
6. The bulb is a twist lock style, underneath the tan cap- twist the cap counter-clockwise, and it will pop out. The bulb is a number 7440, for the running light/ brake light, and a 7443 for the turn signal.
a 3757 will not fit through the cut out hole in the taillight assembly.
7. Re-assemble in reverse, making sure to check the function of the bulb PRIOR to re-assembly.
Good Luck.
SOURCE: Need to replace a headlight assembly for a 2006 Subaru Outback.
No, you just remove the radiator grill and the side marker light and the headlight housing bolts and it comes out. Not a real hard job and is Real straight forward. Good luck and have a good day.
SOURCE: 2001 subaru outback headlight not working
chapmnfarm: your head lights use a "2" fuse system.
one for the left and one for the right.
The fuse box you are looking for is under the hood on the passenger's side. It is a black box roughly 8 inches long and 4-5 inches wide. When you remove the cover, you will see fuses and relays. What you are looking for is the section in the box which has a cluster of 7 fuses. 3 in one row and 4 in the other. On the outer parameter are two relays. The fuses you are interested in are located in the row of 4 fuses, with the two closest to the "L" shaped part of the box. Both of those should be 15 amp fuses.
The fuse below those should be a 20 amp which is the lighting switch and the one below it is a 15 amp which is for the interior lights and the clock.
Check your harness grounds in the engine compartment near the area you have the problem. There are ground wires which come out of the harness on both sides of the core support. The wires are black in color and have "EYES" crimped onto the ends of the wires. Both of them will probably be located about 4-6 inches below the upper tie bar on each side of the radiator. Odds are that the eyes will be large enough to pass a 6mm bolt through.
I hope what I have given you will resolve your problem. Lem me know,,good luck>>>>>>>>>>>>>>>
SOURCE: needdrive belt diagram for Subaru outback 3.0
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: serpentine belt
<img src="http://www.mvreader.com/multiview/dayco/graphics/rtdiag/bkc.jpg" alt="2003 SUBARU OUTBACK - H6 3.0L 3000cc GAS FI N EZ30D" /><br>The website mvreader.com/multiview/dayco has listings for most cars' serpentine belts, as well as their installation instructions.
Hope this helps out,
matthew
