I require a manual for a Technics ST-HD560 Technics System
Posted by tonymeggs on
2 Related Answers
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a technics se-hd560
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 17, 2011
GeoffW1
Geoffrey White
  • 3961 Answers
SOURCE: TECHNICS TUNER ST-X301L USER MANUAL
That's a vintage unit ? You will probably have to pay a small amount to download it from somewhere like
http://www.manualzone.com/service-manuals/Technics_STX301L_STX301L/users-owners-manuals/ReWrite-SPFM-LNG1.Dyn.M39317742KYWRDS_Technics_STX301L_STX301L_service_manual_repair_manual_schematic_diagram_owners_manual_users_manual_parts_list.html
Posted on Dec 06, 2011
How do I programme my Technics ST-Z400l Tuner please?
CUSTOMER CARE PHONE NUMBER IS: 1-800-211-7262 PRESS 0 AT EACH PROMPT, IGNORING MESSAGES. LET ME IS YOU NEED MORE HELP.
Nov 13, 2014 | Technics Audio Players & Recorders
I have a rs-hd560 technics separates hi fi, tape deck broken
Malcolm hi! The tape decks are normally interchangeable as a unit and if you have a remote control that also operate your Hi Fi then you are stuck to the model.
Sep 11, 2014 | Audio Players & Recorders
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
Technics amplifier switches off
1-keep good ventillation around and do not block any ventillation holes with any thing.
2-check your connection cable in good condition no touching of inner conductor with any chasis.
3-check your loudspeakers and apply them to the system one by one until you find the bad one(which make the problem if it is bad)
Jul 05, 2009 | Audio Players & Recorders
THE AMPLIFIER CUTS OFF WHEN I INCREASE THE SOUND.HD560
I've just fixed a Denon amp with the same problem. Replace the mains plug - especially if it a moulded type. Likely that the wires inside the plug have frayed to the extent that there aren't enough strands left to carry the load when the volume is cranked up.
May 25, 2008 | Technics Audio Players & Recorders
135 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
