Dishwashers Logo
Anonymous Posted on Sep 05, 2011
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by opening the door. Now wont start and there is water in the bottom. No lights flashing and only the power light on. Reset didnt work. Any ideas/solutions would be great, Thanks
  • Anonymous Sep 05, 2011
    Thanks. Will let you know what happens.
Level 3:
  • Master 17,130 Answers
  • Posted on Sep 05, 2011
Master
Level 3:
Answers
17130
Questions
0
Helped
3631850
Points
52372
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
    Thanks,but it didnt work. Off to the tip and missus can buy a new one
    Thanks again.
Indesit D63 stops mid cycle
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
GE Dishwasher stopped working after power surge
If you can confirm that the dishwasher is getting power, then there is a very good chance the control board is bad.
2helpful
5answers
My machine appears to start by emptying then filling and then emptying again at which point warning lights 1 & 3 start flashing. Any ideas what 's causing this?
www.indesit.co.uk/_pdf/booklets/02/45/19504701701_UK.pdf
http://home.howstuffworks.com/how-to-repair-a-dishwasher.htm
http://www.the-appliance-clinic.com/dishwasher.html
http://frigidaireservicetips.com/pdfs/486_5.pdf
Above is a service and repair manual, use to troubleshoot your machine, above that are two DIY troubleshooting sites, above that is your user manual, for all your codes etc.
Please try this FIX below, it often works regardless of cause... Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Dishwasher Problems
Check where the pig tail (electrical cord from the outlet) connects to the dishwasher. Remove the bottom panel and you will see the electrical wire from the wall outlet lead into a metal box. With the unit unplugged remove the facing of this metal box and check all of the wire connections. If the wiring is connected properly then the only other thing I can suggest to see if the dishwasher hasn't given up the ghost, is go to the door and open it. At the top of the door itself there is aa small slot that a metal bar on the dishwasher goes into to latch your door. With the door open take a slooed screwdriver and push it into the slot and trip the door lever over as if locking the door to start the cycle. Basically what you are doing is activating the dishwasher with the door open. Once the door latch is in place turn on the timer (keep the door as closed as possible to stop from water spraying out should the unit activate) If nothing happens then with the electrical connections at the base checked, then there is an issue with the electronics in the dishwasher and you may need to contact a service tech to trace the problem down.
Good luck hope this helped
Dave
Indesit idl 705
you may be in "flood mode". there may be a leak into the base. or your bottom base hoses may be blocked, best get someone in who is able to strip a d/w base out.
Indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
2answers
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Top Dishwashers Experts
Mike Cairns
Mike Cairns
