SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
SOURCE: not sure of exact problem
The charger may not be charging the batteries properly.
The batteries you are buying may not be good.
There may be a fault in the camera where the voltage is not being properly regulated.
Your best solution would be to take the camera to a camera service center to have everything properly tested to resolve the issue.
Jerry G.
SOURCE: I have the Canon Rebel XS and it was working
see if you can test the camera with another battery , you may be able to borrow one from a local camera store
SOURCE: Flash won't work in Canon A720IS camera
I was having the same problem and changing to Alkaline batteries seems to have solved the problem. I hope this helps!
