Question about Juicers
I have lost the jug bin of my juicer (where the fruit pulp goes) and am no longer able to use the product as I get waste every where. Could someone tell me where to get a new one from? I have a JE95B juicer.
Posted by julia_tita on
Nikola Jankovic
    New Friend:
  • 31 Answers
I really have no idea where to find a new one, but... I've got Jack Lalenne's Power Juicer, an older model, and I, too, have lost the jug bin. So, what I do, is use a plastic bag. I pull it over the whole opening through which the pulp comes out and add some scotch tape so it doesn't fall off. I'm pretty sure a paper bag could be used, as well. I know it doesn't answer your question, but it can be a temporary solution..!
Posted on Sep 05, 2011
Santos juicer
Couple of things to look at
1 check the grating blade. Maybe clogged therefore need cleaning or need replacing due to bluntness
2 motor may be slipping true to overload. Place fruit in a little at a time
hope this helps
Apr 16, 2014 | Juicers
Where is the safety Switch in the Jack Lalanne juicer express?
The safety switch is on the bottom base where the pulp collection bin goes. If you look on the pulp collection bin there is a small tab that when assembled right deactivates the safety switch. The main arm that holds the top container where you put the produce in is also a safety mechanism that when not in place the machine will not turn on.
Sep 08, 2013 | Jack Lalanne Power Juicer 250 Watts
No problem. question: can you juice wheat grass with the breville juicer?
Not really. You'll get wet pulp and a big mess to clean, not to mention the waste of your expensive products. Here's why-
Best juicer machines for wheatgrass and leafy greens
Aug 16, 2011 | Breville BJE200XL 700 Watts Juicer
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
Mar 08, 2011 | Omega 1000 Juice Extractor
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
My UNIT-does nOt operate at all.
Hey if you have not gotten this resolved already, here are some things to consider.
I have the same unit. It will not operate is any little thing is left undone. So, I would recheck all of the assembly to make sure all the attachments are properly and securely attached.  The last part to check which seems rather minute, but will prevent the unit from working, is to check that the pulp catcher is securely snapped in. There is a small lip at the bottom that must clik in just right for the unit to kick on the switch is pressed.  Once the metal arm is in place, give it a whirl.... and let see what happens.
Hope this helps..
Let me know.
enov8
Feb 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Pupl guard
yes tri star products search it on google.com
Jul 20, 2008 | Jack Lalanne Power Juicer 250 Watts
Wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Jan 05, 2008 | Omega 8005 Juicer
Juicers Logo
106 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
