Question about Nokia E63 Cell Phone
My Nokia E63 won't turn on after a message appeared while opening a text reading, 'Message memory full; please close applications and try again'. When i try to turn the phone on, the backlight is shown and the centre button lights up, but that is all that happens. I have tried factory reset (3, *, green call button and switching on) but it hasn't worked, it has just stayed at the screen with a backlight and the centre button lit up. I can't take and can't afford to take it to a Nokia Service Point or anywhere to get it properly fixed.
Posted by mario_matt on
Anonymous
    New Friend:
  • 15 Answers
For this problem contact your mobile service provider........
Posted on Sep 05, 2011
2answers
My nokia E63 won't send text messages. It will receive them, make calls and receive calls.
First check all the message setting i.e 1.Center number should start with prefix +........Character support it should be "Full" and the "Message sent as" should be "Text".If all these settings are correct the only way to solve is to contact / call the particular customer care.Good luck.
Hi my nokia e63 will recieve text messages and make calls and recieve calls but will not send text messages . its says "memory full, close some applications and try again" . i deletd everything...
here the problem is that
1.your phone memory is full..i hope u deleted only the memory card contents not the phone memory.
and
2.keep your sim free too without storing messages in them .
this will work
My nokia e63 is giving the problem frequently from 3 months, that when i send a text message it is saving in outbox and saying that general memory is full please close some applications and try again,even...
There is some problem in your message setting number, please verify with your operator if its correct. As messages are being saved in outbox; that means that message are not being sent. Please do ask if you have any other query. Have a nice day!
Hi ! Every time I try to send a text message, it appears Memory full! Close some applications and try again.I did erase my pics as well as those file saved in my memory card, but it still hopeless. It's 3...
Go your message setting. There is option where you'll save your message and choose save to memory card.
Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message.
If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most.
If the problem persist, format your phone back to factory setting.
Hope this help and if helpful RATE please.
Feb 09, 2011 • Nokia 3230
2helpful
General memory full close some applications problem in nokia e63
i m not able to send message my mobile......
mu mobie is giving message this type
My mobile will not send text messages. The texts remain in the outbox with a message saying "Resend at", followed by a time. When the message sending fails it displays a message saying "Memory full. Close...
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
8helpful
2answers
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
1helpful
I can not send text message using my nokia N81 8GB phone
well restore to factory settings and it will work i had the same problem , but before save all numbers to mem card or  else you will lose all ya numbers
Nokia E63 Cell Phone Logo
Top Nokia Cell Phones Experts
Ekse
Resolution IT Dubai
Resolution IT Dubai
Oloyede Monsuru
