Question about Lenovo Ideapad U350 Laptop Notebook
I have a Lenovo U350 ideapad. When i rebooted it, it keep coming up Windows Error Recovery. I tried all the options (Safe Mode, Safe Mode with Networking, Safe Mode with command Prompt, Last known good configuration, Start windows normally) but it keep rebooting. What can i do to make it back to normal ?
Posted by marcustoo1e3 on
Jose Cada
  • Lenovo Master
  • 3,530 Answers
Welcome to Fixya
Looks like the Windows OS is already messed up. You should be able to boot the computer to safe mode to troubleshoot the issue. In your case, it is not booting up to safe mode then the only way to use your computer again is to restore it from the factory default state. If you want to do that, just turn off the computer then press the ONE KEY button located beside the power button then follow the on screen instructions.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Sep 05, 2011
OneKey Recovery System of lenovo doesnt work...
Has the HDD been modified in any way, ie the Lenovo system partition been deleted to make more HDD space? If the partition was deleted, the recovery system will no longer work.
May 19, 2014 | Lenovo Ideapad U350 Laptop Notebook
S210
Enter BIOS Choose RESET
Apr 26, 2014 | Lenovo Ideapad U350 Laptop Notebook
Slow internet on lenovo u350
There are so many reasons can cause a Lenovo U350 running slow than it used to, it is hard to identify just what might be dragging down your Lenovo's performance, let alone implement the necessary technical adjustments to fix it. So if you want to address the issues more easily, I'll recommend you try a Lenovo speed up software.
Over 10+ small utilities packed into one to help detect & fix all slowdowns in 1 click.
Aug 22, 2012 | Lenovo IdeaPad U350 (29632YU) PC Notebook
Here i bought LenovoG550..For a longtime i got message "can"t complete the microsoft secuity essentials upgrade installation, Errorcode 0x80070057.
That is an error for the security update and seems windows is not letting it update properly on your lenovo.
you can try and do it in safe mode see if it will work from there, or you can disable your anti virus on the machine see if the update will go through.
If not then try in safe mode if still does not work even in safemode then the last option is reinstalling windows on your machine.
You can try and use the One Key Recovery option on your Lenovo, but if you installed a retail version of windows on your Lenovo then that might be the problem.
Try using he retail disc if you bought one or if lenovo provided you a recovery disc then you can use that to reinstall windows back to defaults.
Back up all you personal files first before doing so.
Have a nice day.
Aug 05, 2011 | Computers & Internet
My lenovo s10 have blue screen of death (BSOD) everytime I start to open the computer's power.
turn on the system and continue tapping the f8 to get in to safe mode and select safe mode with networking, once you get in to windows, do a system restore. and reboot your computer again.
Jul 27, 2011 | Lenovo IdeaPad S10-1208Uw Netbook
Lenovo Y410, It does not boot. Throws error: There was problem in staring windows due to some error. How do I get to start windows in safe mode?
Welcome to FixYa
It seems that you are having problems booting to windows. There are a number of steps you can try to fix this issue.
1. boot to safe mode. Start tapping F8 right after the computer turns on. This would cause the system to boot to windows advanced boot menu. Once you see the advanced boot menu then just choose safe mode. If you managed to boot to safe mode then you can perform system restore from here. To run system restore just click on start, all programs, system tools, then click on system restore, once system restore has been launced choose a date when the computer was working fine
2. You can also try to boot to windows recovery environment. to do this keep tapping F8 right after the computer turns on. choose the option "repair my computer". The system would now boot to windows recovery environment. From here you can run startup repair and system restore
3. If none of the above steps work then you can use the One Key Recovery feature of a lenovo Y410. Please note that this would reset your computer to its factory image so this would cause you to LOSE DATA on the system. Before you use this feature make sure that you have a back up of all of you data. Note that the computer must be turned off. Press the NOVO button on the computer. refer to the image for its location on your computer
Pressing this button while the computer is off would launch the one key recovery of lenovo. From here you can restore the system to its factory condition.
Hope this helps
May 22, 2011 | Computers & Internet
How to restore lenovo ideapad U350 to factory settings without discs
Pressing the OneKey Rescue System key will activate Lenovo OneKey Rescue System when your PC is turned off. Within the program, you can restore your system partition to the original factory status, or to a previously generated backup. You may also transfer critical data or documents to other storage devices. All these features make OneKey Rescue System an important utility for securing your data. Note: It is not recoverable if Restore to factory default or Restore from backup has been run. Make sure to back up any critical data before you run these features.
Oct 27, 2010 | Lenovo Ideapad U350 Laptop Notebook
My y650 ideapad turns on, tries to load Microsoft
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084 -
Apr 10, 2010 | Lenovo Y650 4185-55U PC Notebook
Lenovo Ideapad U350 Laptop Notebook Logo
537 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
