Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
F3 flashing on display - Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Posted by kawzx9262 on
Gene Meier
  • 2,341 Answers
The F3 error code means the the oven tempature sensor has shorted out and the sensor needs to be replaced. This is what the sensor looks likef3 flashing on display - oldtech2332_89.jpgTo check that it is shorted,unplug it and place meter leads at the plug on the end of it and see if the display on your meter shows 0.00 ohms of resistiance...if it does the sensor indeed has shorted out,a good normally working sensor shouls have a reading of between 1060-1100 ohms resistiance at room temp. a reading of ZERO means that the sensor has shorted and needs to be replaced. the part number for the sensor is 316490001 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
GENE
Posted on Sep 05, 2011
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F3 keeps flashing on the display
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | GE 30" Built-In Single Electric Wall Oven...
Oven goes out ,display flashes --F3-
Hi jstpchy1953,
F3 code error means open oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Oct 24, 2010 | Tappan TGF320 Gas Kitchen Range
Display on kenmore electric double oven flashes F3 soon after setting temperature and oven turns off
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%%
Jul 19, 2010 | Kenmore 41389 Electric Double Oven
Display reads " -F3-
Replace the oven temperature sensor. Unplug the range. Open the oven. The temp sensor will be in the top right or left of the oven.A short metal piece about half the size of a pencil. Remove the screws,pull it out carefully. Disconnect the wire plug. Reverse this order to install the new sensor.
Sep 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
JENN-AIR MODEL D156B Electric oven
Hi Sadirrd
Your problem (flashing F3) is most likely a defective temperature sensor.It may also be due to a open in the wiring harness connected to the sensor - unlikely but could be.
Post a rating for this solution
Regards
Nov 07, 2008 | Cooktops
Roper gas range Model# FGS337GQ
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0
F5 - E1 and E2 Door latch problem Check door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of your model # 0-5 that will determine which control it takes. Once you have that # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Nov 04, 2007 | Kitchen Ranges
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
164 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
