Question about GE 28111 Cordless Phone
I love my GE Model 28111 Series DECT 6.0 Cordless Handset Speakerphone System. However, I goofed the other day and accidentally left it outside and then it poured. Needless to say, it is totally shot. My question is, can I order a replacement for just the one phone? The one that is totally shot is Handset 2
Posted by jpinn3 on
Anonymous
    New Friend:
Your GE phone doesn't have an accessory handset. Unfortunately you cannot replace it with just one handset. If the phone is within warranty, kindly return it to the manufacturer and have it replaced.
Posted on Sep 04, 2011
How do I access the battery in the cordless handset
GE 30524EE2 DECT 6.0 Corded/Cordless
Don, Battery replacement is on page 13 on the first link. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE 30524EE4 User Manual Battery Installation
http://www.videofon.rs/ge/pdf/30524.pdf
http://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf
My g.e. model 28111 series dect 6.0 dual handset speakerphone system keeps flashing (both on the handsets & one base) that a message awaits. I recently changed providers from shaw to telus & do...
GO into phone setup, and set it to the default setting and the message cleared and the light stopped flashing.
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps you
Best regards
John.
Hello i have a ge 28118 series slim dect
My phone is making a lot of noise and static on in coming call so bad I can't talk. out going I can't make. I put in the number to dial call does not go through ,but I can hear the dial tone. do I need a new battery or is there something wrong with the phone itself.
32helpful
5answers
New Voice Mail flashing light
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
1helpful
Model 28111 series dect 6.0 GE phone
I'am subscribed to three way calling from my phone company, but forgot which button to push to connect three way call on my phone is it the green talk button that is in the middle of my phone.
3helpful
2answers
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
10helpful
5answers
GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
1helpful
Registration
I'm not sure from your description exactly what your problem is, but I have the 28112, and it has a handset menu command for registration, and one for deregistration. If this sounds similar to yours, I'd suggest trying the registration command. If that fails, try deregistering, and then try to register again. I've also heard that these units somehow reset after 20 seconds in the recharge cradle, but I haven't seen that actually appear to work.
If you have problems getting the menu command to work, write back with more info and I'll see if I can figure it out based on what my phone does.
GE 28111 Cordless Phone Logo
Top GE Lands Phones Experts
Ekse
Oloyede Monsuru
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
