Samsung DVD-VR375 DVD Recorder/VCR Logo
Posted on Sep 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to attach dvd/vcr player to cable box and hdtv
Anonymous
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Oct 03, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
59
Questions
0
Helped
12298
Points
137
DVD/VCR will take inputs of either component BGR RW or composite YWR and will provide either composite or HDMI output. My suggestion is to take the "best output" from the cable box you can and use the HDMI output to your HDTV. This will take the best your cable will offer and give your TV the best signal to use.
Cable box ------ to DVD/VCR ------ to HDTV.
David Payne
Level 3:
Top Expert:
  • Samsung Master 14,162 Answers
  • Posted on Aug 13, 2015
David Payne
Samsung Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2995647
Points
455836
I have a 70" element TV bought used no remote how do I get the DVD player to work? What channel ??? tv av component etc.....
How do I hook up my tv,dvd player,vcr, and cable box?
askville.amazon.com > Entertainment > Television
Dec 3, 2009 - Recent Questions About: hook tv dvd player vcr cable box · Entertainment > ... Exclusive Coupons To Get 30% Off ... Check the back of your TV to see which type of hookups are available and use the appropriate cables.
Element 46" Class LCD 1080p 60Hz HDTV, ELDFW464 ...
www.walmart.com/ip/Element-46-Class-LCD.../17188433
Walmart
Rating: 4 - ‎190 votes
The Element 46" 1080p HDTV features a brilliant full-HD picture for your viewing ...ShippingPass. H&R Block Tax Software 15, Deluxe + State. $34.70 .... I really cant stand having to use another remote...thats the point of having a .... Just a regular DVD player and it works perfectly fine with the TV. ..... Get to Know Us.
5 Easy Ways to Hook Up a DVD Player (with Pictures)
1helpful
2answers
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
2helpful
2answers
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
2answers
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Magnavox DVD/VCR Dual
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
2helpful
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Dawoo DVR07
you need specials cable for your conectiviti
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
