Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Sudenly kingstone usb changed to skymedi and doesnt formated
Posted by susei_heart on
Ishadi Sidiq
    New Friend:
    Problem Solver:
  • 6 Answers
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Posted on Sep 28, 2011
My usb (kingstone skymedi 8gb) driver is reading as 0bytes capacity
Format it by going to the Explorer and right clicking then click "Format", press format on the prompt and wait for it to finish.
Have fun :)
Aug 14, 2011 | Computers & Internet
My 8gb kingston usb falsh automatically canged to skymedi and also not formated ,no copy , write protected error , plz help me wht to do ????
no need to worry friend first you need to active the usb port and then fix the pendrive to usb
follow bellow steps
---> ctrl+R
----> in this tyoe " cmd "
-----> in command prompt type usb drive name
examle : if drve is H then type like H:/ or F:/ etc
----> format H: or format F:
-----> if any question ask then u aswer yes press "Y"
----.> your problem is solve
in case failure then you can try this another operating system or another computer
Feb 22, 2011 | Kingston Technologies 512MB DataTraveler I...
My skymedi 8GB write protect,
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 19, 2010 | Kingston Electronics - Others
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant...
Hi
try to format your kingston with
Following tool.(HP USB Disk Storage Format Tool )
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
Oct 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston data traveler shows as skymedi drive
You can follow the below commands
got to run
type cmd and press enter
then formatdrive name: and press enter
then it will ask for yes or no
press y
again do the above step once again your drive will be format
Jul 01, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston DT 101 II Usb Device become SKYMEDI USB drive
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
May 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
Feb 20, 2009 | Kingston Technologies 512MB DataTraveler I...
512MB KINGSTON DATA TRAVELER BECOMES SKYMEDI USB DRIVE USB DEVICE..PLS HELP
I think that I have a similar problem (and a potential solution)
1. My thumb drive is 4GB "super talent", and I have used it for about 2years
2. Suddenly, it show up as "REMOVABLE" SKYMEDI USB DEVICE (!)
3. I tried "google" for answer... and did not get further
4. Finally, I righ click on "my computer" -> select "manage" the "computer management" MMC windows open
4.1 I tried the "Disk Management" and it still can not connect to it
4.2 I clicked on "Removable Storage" ... and then I "SKYMEDI..."
4.3. I righ click on the device and select "Task" -> "Free" (thinking ... what can be worst!)
4.4 ... sunddenly ... I see my drive back ... with everything on it....
I hope that this help (... I am guessing that the "removable storage" manager locked this device somehow)
Regards
Jul 07, 2008 | Kingston Technologies 512MB DataTraveler I...
I can't format my 512MB kingston data traveler
Dude I just fixed mine running the SKYMEDI tool version SK6211BA_20080917 on my 8GB kingston datatraveler 100 is hard to get it but you will find it, you need to determine what version of the sw applies to your flash drive, check the SKYMEDI website www.skymedi.com.tw
Computers & Internet Logo
1,735 people viewed this question
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Mike
Harish  Ramaiah
Harish Ramaiah
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
