Andis 04603 Hair Trimmer Logo
Posted on Sep 04, 2011
My T- Outliner Andis Clippers won't cut as sharp and they are brand new. How do I adjust the blades?
5 Related Answers
A
Anonymous
  • Posted on Jul 02, 2008
SOURCE: Andis T-Outliner
you move the inner blade up so it cuts sharper. take the blade off, loosing the 2 screws on the inside, move the plastic up and put it back together
Anonymous
  • 61 Answers
  • Posted on Apr 01, 2009
SOURCE: My Andis Masters
tention is probably to tight, or blade needs to be realigned
Anonymous
  • Posted on Jul 21, 2009
SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Anonymous
  • 32 Answers
  • Posted on Oct 08, 2009
SOURCE: Misses hair when cutting
try adjusting the screw on the side of the clipper
A
Anonymous
  • Posted on Aug 30, 2008
SOURCE: andis outliner
Andis factory for repairs at 1800 Renaissance Blvd Sturtevant WI 53177
5answers
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
2answers
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
2answers
How do i sharpen the blades on my andis t-outliner, and give it whats called the New York, or east coast ...??
On the Andis T-Outliner trimmers I recommended sending it to a pro, these trimmer need to be adjusted correctly and the blade needs to be sharpen by an expert. at Mannys'Sharpening they have 20 years in the sharpening b's and they are experts in Andis T's they specialize on them. Manny's Sharpening has a mail order service they charge $15.00 to service & sharpening your trimmer plus the return shipping is free. the way you pay is via email via PayPal. and they will hook you up they way you want that trimmer blade to cut. check it out at Mannys-Sharpening.com also check their reviews on yahoo local.
1helpful
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
How di adjust blades to make andis clippers sharper
Take blades off clipper,loosen screws on blade, place on mirror, rest teeth against mirror, angle clipper at 1 oclock position, slowly titen screws
2answers
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
My Andis Masters
5helpful
2answers
My GTO model Andis clippers blade is not properly aligning..how do I adjust it? I BOUGHT NEW BLADES FOR MY ANDIS LINER BUT IT STILL DOES NOT CUT SMOOTH AND SHARP. WHAT IS THE PROBLEM.
1helpful
2answers
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Top Andis Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kolbrun...
NOEL
NOEL
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
