Maytag Neptune FAV6800AW Top Load Washer Logo
Question about Maytag Neptune FAV6800AW Top Load Washer
Leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you get in to the back of the washer?
Posted by gary0101296 on
Anonymous
  • 526 Answers
The FAV6800A and FAV9800A only have access thru the front panel and washer top once released fromt the base......no rear or side access. See Pick of Outer Tub removed for Tub Seal and bearing replacement.
Google ""16022808.pdf"" to find the Service Manual.
Page 33 will show ou how to release the top cover and page 41 for front cover removal.
If you have wash water leaking down on the Clutch Pulley I feel you have a Tub Seal leak. The issues could be related to the drain hose/drain pump or cracked outer tub.
I don't troubleshoot on this forum to difficult to carry on thread. Google ""Neptune TL Washer FAV6800AWW"" or ""FAV6800A/FAV9800A Outer Tub bearing replacement"". Two DIY forums I frequent that I feel are true DIY forums.
Posted on Sep 05, 2011
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
I have a Maytag Neptune TL Washer that won't drain. I think the drain pump is clogged. How do I remove/disassemble the cabinet so I can get to the drain pump?
See this link for the Service Manual and a pic of Drain Pump/Drain Line on the right side of the machine. leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you
You can place the machine in Service Mode once you have the Service Manual and turn on the drain pump thru console commands.
As I mention in the other post here on FIXYA you can only access the drain pump with the front cover removed.
If you place the machine in a Spin Only cycle will it complete the cycle?
If you can give a bit more detail on your troubleshooting maybe I can help.
1helpful
Amana NTW5245TQ1 Topload washer....water draining out from basket...
Unfortuneately, I think you have two seperate problems. Fortuneately, this is easy to verify. As far as the not spinning, it is generally caused by loose hinge screws on the lid. There is a arm that sticks off the back of the hinge to press on your lid switch. If the screws are loose, the arm generally wont be able to press the switch. Just tightening ther screws on the right and left hand sides of the lid corrects this. You can verify this has corrected the problem by setting the washer to spin without adding any water. As far as the leaking. Well, there are multiple sources for this, but the most common is the water pump. To verify this, unplug your unit and pull it out from the wall. Tilt the top of the washer back towards the wall until it rests by itself at about a 45 degree angle. You are looking for a white peice of plastic towards the bottom front of the machine. There will be 2 black hoses going into it. run your finger across the front side of it feeling for bumps. You may have had something get lodged in there and poke a hole. If you can not find any moisture on the pump (yes it can leak from the hoses of back of the pump also)look for any signs of water having leaked. (you generally get water spots just like in your dishwasher when you don't use a rinse agent). If you still can't see anything, tilt the unit back forward and add 1 cup of water to the machine. Tilt it back again and see if it's leaking. Continue adding water until you can get your leak then trace the water back. However, if you do in fact have a bad pump, they are availible from local appliance parts suppliers (in the phone book) or on-line from the maunufacture. Any troubles or other problems? Drop me a line back. Otherwise,
2answers
Washer leaking from bottom
Take the front panel off of the washer, and run it through a cycle. Watch to see where the leak is coming from. Also, pay attention to the drain in the wall when it is in spin/drain. If this has a blockage in it, it might be backing up causing water to come back out of it.
If you see no leaks the next time you run it, it's possible that it splashed over while spinning because of the off balance load and may not happen again unless it becomes off balance again.
7helpful
2answers
Whirlpool washer machine
I suggest you remove the front of the washer and observe the base of the drum and all hoses while in operation, using a flashlight attempt to find the source of the leak. **USE CAUTION!** Moving parts, water and electrical components present a very real hazard! If you have a top loading washer which agitates the clothing back and forth, one possible cause is the transmission. There is an internal locking mechanism which sometimes fails and will not engage, allowing the drum to continue to spin in one direction. The water will rise as the drum gains speed until it reaches the overflow outlets at the upper portion of the drum. These overflow outlets allow the water to spill out inside the bottom of the washer and out onto the floor. To check this, run the washer with the lid open (to do so, use a plastic or dry wooden stick [something non-conductive] to push down and hold the safety interlock switch closed) if the washer does not agitate back and forth and only spins in one direction you have a transmission problem. JUST BE CAREFUL WHEN OPERATING WITH THE INTERLOCK BYPASSED AS YOU WILL HAVE EXPOSED MOVING PARTS! If you feel any hesitation or concern about doing this...STOP!!, get someone comfortable or certified to do this type of work. While it is not difficult to do these things, there are risks and a momentary distraction can be painful, disfiguring or deadly. In this case, a repairman can be cheaper than a trip to the emergency room. You be the judge of your own skills and abilities.
Good Luck
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Top Maytag Washing Machines Experts
Robert
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
