SOURCE: HP Laserjet 3050 won't print - os X
Power off printer, disconnect all leads such as USB, network, etc and power on again.
Does it power on to the normal state?
Are there any messages on the control panel or light patterns (eg off, on, flashing etc)?
SOURCE: HP Officejet L7780 Scan Wirelessly Using MAC
HI,
Yes, surely its possible as long as you installed the SW properly in to your computer.
Thank you so much.
adonscott
SOURCE: My HP470 OFFICEJET refuses to print
I did manage to solve the problem in the end. As it seemed to be a communication problem, I restarted my Mac (as opposed to switching off the printer and on again) and it worked!!
Might need you some time in the future though....
Thanks,
S Walsh
SOURCE: I have an HP photosmart premium fax C309 series.
Hello
Based
on information you have provided I understand that you have problems with your Printer. I realize the
inconvenience it may have caused you. I will provide my best
information to get a fix for this issue.
As per my analysis,
Issue : Mac OS : Scanning with HP Scan Software
Printer : HP Photosmart Premium Fax All-in-One - C309a
OS: MAC
The solution for the issue you described is provided in the online HP knowledge-base article Link :
I Cannot Scan on MAC
Setting up and using the Product
Scan Does not start
Thank you,
Cheers
Tejodhar Atreya U
SOURCE: how to connect c309 printer to wireless PC
IT WOULD BE TOO LONG IF I TYPE IT IN
AND ALSO THERE ARE NO OF DIFFERENT WAYS
SO U CAN SIMPLY FOLLOW THIS LINK AND HOPE IT HELPS U
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631592&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=3979722
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
