Good day!!!!
That problem is cause of shorted bridge diode or power mosfet..
just see the picture below to see the image of bridge diode and power mosfet..
If you don't have a tools or you have no electronic background you only have to is order the new power supply board..
I hope this solution will be helpful..Thanks for using fixya....
The problem is in the power supply board. The power supply board has the 110 volt AC cord attached to.On this power supply, there is a shorted diode. The location is D621. It is next to the red, black and white wires attached to the inverter board. Snip one end of the diode and lift it to clear the board. Do not replace this diode, the TV will operate with out it. Replace your AC fuse (4amp gma fuse). Thanks for asking, Matt of Martins TV Repair.
Thank you Matt Martin for your valuable expertise. I did exactly what you said and my tv now works. Before I saw your post I tried to deal directly with Phillips and that was an absolute joke.
Brian you are most welcomed. I really don't believe in the mumbo jumbo talk about TV repair. I prefer...get to the root of the problem and lets get it fixed!
I am an ASC for your TV.
SOURCE: where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
