Health & Beauty Logo
Posted on Sep 04, 2011
The batery was burnt and wiring i taped wireput a new batery onthe reset has mechancal prroducts on side 1648-025 060 60a under that 125 250uac 5190
Hook up cable wrong to jump batery on tractor. Big puff of smoke, burnt wire.
Cut & Strip wire thats burnt, replace wire and use shrink wrap wire connectors. Crimp wires and heat shirnk tubing to keep moisture out.
Jan 25, 2016 • Garden
91 jeep wrangler started and ran when z jumper wire from ecm to coil was attached
check your wiring harness----Jeeps/Chrysler prroducts---have a lot of issues with their harnesses---corroded wires and relays---you'll probably need a schematic and a meter to check this out
2answers
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
1helpful
Can't eject tape
"first remove the power to the unit, pop the top lid off, (4 screws) then u will see a controle board secured on top, there are 2 screswes on teh side, becareful not to break any of the wires connected to the board when sliding out of the way. below this board is where the tape is located. You should notice a number of visable plastic grears onthe side of the loading mechanisim. there reall is only one u need to be concerned with, It is Located on the left side of the motor, motor is located to the rear left side of the mechanisim. there u will see a long a FLAT gear, just to the left of the motor, there is a small amount of play in this gear, push this geer twords the rear of the unit and hold it there, reinsert the powersupply and press eject, this will tigger the eject mechanism and pop the tape out"
2001 CHEVY CAVALIER HEADLIGHTS AND WIPERS DONT COME ON. SWITCH ALREADY REPLACED. I PULL FUSE FOR PCM AND HEADLIGHTS COME ON CAN IT BE THE FUSE BLOCK WHICH IS LOCATED IN ENGINE COMPARTMENT. NEW FUSE...
This sounds like anelectrical short, check the wiring both under the hood and under the dash for burnt of frayed wiring, bare or cut wires, possibly even electrical tape. A haynes manual may came in handy and can be picked up at you local parts store.
My blazer will turn over but won't crank, Why? And yes it has gas..lol
Won't crank as you called it is another term for turning over. What you ment to say was your car will turn over but will not start. Is this correct? If so first check your ignition fuse on the fuse box located most likely under the left hand side of the dash. But it could be under the right side or even in the glove compartment. Once you locate the fuse box then find the one that is marked ignition. Pull that fuse and see if it has a good wire inside the tiny view window onthe fuse. If it looks burnt then replace it and that should cure what ails your car. If not we need to go further in to detail. Let me know and I will be glad to help. Raz
1helpful
Battery would not charge while bike is running.
u sure the alternator is producing-hows the wire connections to batery-inspec fuses n other partz of harness
Electrolux EOB5600 electrical fault?
goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
john h
Steve Pack
Steve Pack
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
