Hoover AAA140 Front Load Washer Logo
Question about Hoover AAA140 Front Load Washer
Hi. I just bought a Hoover vision HD 1400 aaa. But i didn't get the user manual, and i am totally green when it comes to washing clothes. i've been around checking out local stores, but nobody seem to have the manual. I really need to know what each programe does to my clothes..
Posted by vic_fotball on
Anonymous
    Brigadier General:
  • 6,277 Answers
Being from the UK I am amazed that vendors elsewhere seem not to supply manuals automatically with each machine!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Sep 04, 2011
Testimonial: "Thank you very much :) It was very helpful !"
How to reset the delay start on a hoover 1400 AAA vision hd
consult the manufactures website for a manual free download eric
Hoover vision hd 1400 aaa manual
I have hoover vision hd 1400 aaa
In proble stain blaster
I oll redy clean thing and check water vest pipe
Nothing to blocking
1helpful
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
1helpful
Hi i have error code 4 on my hd vision washing machine can you help
Error 4 for Hoover HD Vision machines decodes as 'antiflood pressure stat, faulty inlet valve'.
Sorry but that means a repair man visit- nothing we can do other than advise that ;-0(
If this has at least clarified the situation with your washer please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
3helpful
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
8helpful
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
18helpful
2answers
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
1helpful
Washine machine fills but drum does not turn
hoover hd 1400 aaa motor turns and so does drive belt but the drum doesn't? what is the problem?
3answers
Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Top Hoover Washing Machines Experts
W.L.
Steve F
Mike
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
