Whirlpool AWM 293 600. Machine sometimes doesn't start when the door is closed. Seems slamming the door is only way to get it going, now won't start at all.
This problem is usually the front door latch "interlock" is not engaging. This is the safety device which keeps you from opening the door and pouring gallons of water on your feet. When you close the door, if the machine DOESN'T recognize it's closed - all electricity is cut off and the machine does nothing. If the machine DOES recognize the door is latched, the latch will lock and you can't open the door (for about 90 secs after you turn it off or unplug it). Does the door LOCK when it's closed? If not, just close it harder several times. A medium "slam" almost always takes care of a "sticky" interlock - and it doesn't hurt anything.
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
The flashing light means that the machine thinks the door is not closed (The door lock switch is not activating). 99% of the time this is simply a sticky switch and the solution is to give the door a good firm slam shut (Don't get silly here, but it will take a pretty good "teenager slamming the bedroom door in a temper tantrum" type slam).
In the event that this doesn't work, then you're looking at a faulty door interlock switch. They're not that hard to obtain or fit if you're fairly confident. Drop me a comment back here and let me know how you get on. Happy to help further if the above hasn't allowed you to solve the problem.
Knowing the make and model of your machine would help!!
This sounds like a Zanussi/Electrolux error code. If it is then E40 means "Door open, door interlock, wiring or main PCB"
I'll presume that you DON'T have the door open, so lets move on from there. There is a sensor on the catch when you close the door (Its the one that locks the door when you close it so you can't open it in mid cycle). It also checks if the door is closed so it can lock the door. It MAY be that a good slam of the door will fix the issue because the catch is a bit sticky.
Equally as likely is that at some stage recently you have already slammed the door, or the machine has had a very uneven load that has caused it to shake violently, making one of the 2 wires on the sensor fall off. This will also cause an E40 and is a not uncommon fault.
If the slam doesn't get you anywhere, have a go at the following:
POWER OFF - MACHINE UNPLUGGED FROM THE WALL!
I'm making a few guesses here as I don't know the specific machine
Take the lid off the machine (Usually a couple of screws at the back of the machine at the top, undo them then give the lid a sharp thump with the heel of your hand to push it forward or backwards (The way the lid was held on by the screws should give you a good indication of which way the lis comes off, it MAY even have a couple of screws in the side near the top, hidden under a couple of little plastic caps).
Once the lid is off, take a look at the sensor for the door. It is directly mounted around or on the door catch, so use the position of the catch on the outside of the machine to figure where it is - This is going to be a tight squeeze, it will be made easier if you tip the machine back by 45 degrees so the drup suts back in the chassis and gives you more room.
You should clearly see 2 spade tags on the sensor with a wire on a spade connector attached to each one. If one is off - good news - put it back on (You might want to give it a squeeze with a pair of pliers to tighten the conenctor up a bit so it doesn't happen again.
Reassemble - Job (Hopefully) done.
If the wires were in place and the door slam didn't work, it could be the main control board that is faulty. IF the fix above didn't work, you probably need to call out someone who can test and fix it.
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Hi
Seems like the door switch is failing, or failed.
wpecially if a front loader, the door has to be closed, and register on the circuit as closed before the machine will start.
they are cheap and easy to replace, most of the time, but cant give instructions for an unknown whirlpool other than
take front panel off
replace door switch
replace front panel
