Balance CM2019 19" LCD Monitor Logo
Question about Balance CM2019 19" LCD Monitor
I need the drivers. or the web site can not find it on the web
Posted by vogeyone on
Anonymous
  • 531 Answers
Hi
The .inf drivers for almost any computer monitor is already built into ALL operating systems.
There are, generally, no drivers necessary or available for monitors.
This is the way it works. A computer's Graphics Card (which is, effectively dedicated a mini Motherboard with its own dedicated RAM Memory, Heatsink and/or Cooling Fan and Microprocessor - GPU), purely to power and manage the overall graphics capability of the computer. The Graphics Card does most of the work involved in taking encoded or decoded image files from your computer, from a DVD or VCD, from the internet or from a typical, external imaging source like a Smart Phone, Webcam, Digital Camera, Camcorder or a Media Player and then and interprets these image files into the analogue or digital signal (depending on monitor type) it sends to the monitor for it to resolve into an image.
A monitor has a range of Resolutions it can operate within, and if the Graphics Card or Graphics Chip Setting are set too high or too low, outside this range, the next time the computer is restarted or shut down and powered up again, the monitor might be incapable of resolving the image and therefore remain blank, as the computer boots, leaving the user blind to its Desktop.
Other faults preventing monitors from displaying images include foreign metal objects or bent, touching, pins shorting in the connectors at each end of the VGA (Analogue) and DVI (Digital) Video cables that link the Monitor to the computer. The cable may also have a failure or a fault somewhere along its length or a failed connection at the junction of cable and connector.
The quality of the image displayed on the Monitor is mainly governed by the resolution of the image, which is controlled by the software governed settings of the Graphics Card
If none of the above is preventing the Monitor from functioning then the Monitor might have an internal fault. The inside of Monitors and TVs are a hostile, non User Repair Friendly working environment, with lots of capacitors storing relatively high charges even when the monitor in not connected to the mains electricity, that can seriously injure or even kill an inexperienced repairer.
Internal monitor repairs are rarely economical because a successful repair often requires the replacement of a faulty internal component, the cost of which, when added to the labour cost involved in the repair, is unsustainable, given the widespread availability (due to the rapid uptake of HD technology) and relatively low cost of Warrantied new and 2nd user models in the marketplace.
If your Monitor is powered by an AC/DC Power Adapter, check for any faults with the Adapter that might be preventing the power from reaching the Monitor and if, found, consider a replacement adapter from here or from similar sources to this:
http://www.ebay.com/itm/NEW-AC-Adapter-Balance-Digital-Technology-EZ17J-LCD-/320744475938?pt=LH_DefaultDomain_0&hash=item4aaddc4d22
If the monitor proves to be faulty and none of the above solutions remedies the fault, it may be time to consider buying a new Monitor.
Definitely do not waste any more time looking for Monitor Drivers.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. This helps Answerers, like me, better understand the needs and the point of view of the Asker and guides us in exploring the best ways to provide useful, high quality Responses.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Posted on Sep 04, 2011
Terry Hale
    New Friend:
Fantastic information, virtual_a. Thanks so much for taking the time to answer. I too was looking for the same thing. Found the .inf file, but it won't install on Vista. After looking at it, and reading what you said, I realize it's just a waste of time. :)
Posted on Jan 04, 2013
2helpful
I need to download SONY VAIO E Series VPCEB34EN MODEL NO PCG 71211W drivers
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
How can i install web cam
You need to install the WEBcam driver from the installation CD that was supplied or download the WEBcam driver from the WEBcam manufacturer's WEB site.
If the WEBcam is built-in on your laptop then you can install the WEBcam driver from the installation CD or download the WEBcam driver from the laptop manufacturer's WEB site.
I need a recovery disk for my laptop, SONY VAIO VGN-B3XP
You may be able to get a recovery CD from the Sony WEB site.
I NEED DRIVER VIDEO WIN7 64 BITS FOR NOTEBOOK VGN-SZ450FN.
You may be able to download a Windows 7 audio driver for your model laptop from the Sony WEB site.
3helpful
2answers
I need a camera driver for my laptop neo m72s. where can i download it?
You can download the driver from their WEB site. This is the WEB site.
http://www.neo.com.ph/support_drivers_and_technical_issues.aspx
2answers
I need the driver of web cam so you can help me? my pc is not have driver of web cam so i need driver...
Hi
simply go to www.logitech.com and download the much needed driver there. it is the official site for logitech product and its trusted
4helpful
2answers
No lan and sound driver
Hi, can you please give me your computer model and the operating system of it... I can get you the sound and lan driver:) Thank you
26helpful
I need USB driver for Sony DCR-HC23 windows 7 64bit. I cannot find it on the web or on official Sony web site!
I need the drivers for the dvd rom for an asus L3500Tp
Google the ASUS web site, look for support, and then download drivers for your equipment. Practically every driver is available from the hardware manufacturer's web site. If it is not, then there are other web sites that maintain a collection of older drivers for hardware no longer manufactured.
2answers
Problem with creative web cam VF-0330 i am using creative web cam VF-0330 and But i lost the driver CD........ Please if any one have, Send me the link
your driver is here
We are currently negotiating with our Hosting company to Add over 100,000 Windows Drivers for
Windows VISTA
Windows XP
Windows 2000
Windows 2003
This we hope will allow all users of the site to be able to find the drivers
they need at any time without having to trawl the many dead ends on the web
so spread the word and bookmark our site.....
The site and drivers are absolutely free to download and use...
the cost of this will be born in 3 ways
1. PC Leeds will donate time and site costs.
2. Revenue from google ads.
3. Donations from site users.
so there are a few ways you can help keep the site up and free.
visit www.pcleeds.com/drivers.html for more info.....
Top Balance Computers & Internet Experts
Jaime Hernandez
NOEL
NOEL
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
