SOURCE: Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
SOURCE: need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
