Question about LG LDF8812 Stainless Steel Built-in Dishwasher
Drain hose cracked and needs replacing on my lg dishwasher -- how do you get at it?
J. KUYKENDALL
  • 51 Answers
You will have to pull the dishwasher out. and it is best to lay it on its back in order to get to it. there is also a clip in the bottom that holds it in place, all you need to do is pry it up and thats it all set.
Posted on Sep 04, 2011
How do I install a new drain hose in my LG dishwasher the original cracked and flooded my floor
You will have to completely uninstall the dishwasher to replace the drain hose assembly.
Part# AEM69493803.
Once the unit is out of the cabinet drain hose replacement is fairly easy.
Jan 14, 2010 | LG Dishwashers
My LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code LE comes up after 2 min. when trying to run the dishwasher. We had the motor replaced when dishwasher was 1 year old then again a year later. It has been less than a year and it is doing the...
I had the same problem. It was caused by 1 or more wires in the door that have cracked and split apart. I cut the bad sections out and reconnected the wires and it works now. The LG's are known to do this. LG said they would send all new wire harness but it would cost $200 to have a tech put it in. LG would not cover the labor.
Jul 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG dishwasher drain hose
You will have to remove the dishwasher from the cabinet, lay it on it's side, and remove the bottom access cover to get to the end of the hose. (it's usually not as bad as it sounds)
Mar 18, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
The water does not drain out. Water in tub bottom
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Amana Dishwashers
Dishwasher leaking at the bottom of the door during operation.
hi If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
thanks....................
Sep 12, 2008 | Whirlpool Dishwashers
Oe code on LG dishwasher following garbage disposal replacement
Hi. I just had the same trouble. Your garbage disposal comment there gave me an idea. The drain hose from your dishwasher likely goes to the garbage disposal and then out the drain. My hose had a little blockage at the joint where the hose goes into the disposal. I was able to clear it just by giving it a wiggle....all is well now.
Good luck.
Sep 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
May 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
225 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
