Question about Psi 2500 Mobile Pressure Washer 5hp Honda Engine
My Honda Pressure washer will not start. I have drained the old gas an replaced with new.
Posted by salliebrackm on
Curtis Sewell
  • 7,482 Answers
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting a nice blue spark then:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the pressure washer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Sep 03, 2011
I put 2 cycle gas in my 4 cycle Honda gcv190 pressure washer
did you pull the spark plug out and clean it ? if you did , did you also put the starter cord and turn the motor over without the plug installed to get rid of the 2-cycle oil out of the cylinder ? if not do so.
Jul 19, 2013 | Honda GCV190-N5AP 187cc GCV190 Series OHC...
13 horse Honda presure washer (landa) won't start. Been sitting for several years. Checked plug which looks new.. Maybe wrong one? Will sypone old gas and replace. What about plug, fuel filter and air...
you can try and remove the old gas the carburetor and perhaps the fuel filter are most likly fouled with gunk from the old gas. When gas sits, over time it forms a thick gummy deposit that can clog carburetors, and anything else. try fresh gas with some carburetor cleaner (NOT the kind in the spray can) mixed in. It may need to have the carburetor rebuilt or replaced.
Jul 10, 2011 | Honda Garden
I have used my Honda Pressure washer 3 times over a period of 1-2 years. I could not get it to start today. I did not drain the old gas but added some new gas (which was probably a few months old). I...
check the oil level in the crankcase if it just spills out the oil fill hole it fine
drain tank and drain float bowl and clean fuel tap make sure the carb is not green and blocked if so give it a good clean out make sure all jets are clean and clear- make sure fuel flow is good and carb connection and @ fuel needle valve / seat
make sure has spark
make sure muffler has no mason bees blocking muffler
give it a try
cheers pauly46
Jan 15, 2011 | Honda Pressure Washer PSI 3000
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
I have a excell 2600 honda 5hp gc 160.It has not been used for over a year. I empted the old gas out & put in new gas. It will start but when I push the choke in it shuts off.
A couple of things....
Clean the air filter and make sure it is dry.
Check for any springs that have come off of the linkage.
With compressed air, blow out the carburetor.
Clean and clear out the fuel tube from the tank to the carb housing.
Be sure you have proper oil level.
Out of what you have said...it is something in the carburetor....probably needs a flushing with air.
Give it a try and post back!
Jan 19, 2010 | Honda Pressure Washer PSI 3000
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Apr 12, 2009 | Honda 8 HP Engine
Psi 2500 Mobile Pressure Washer 5hp Honda Engine Logo
1,827 people viewed this question
Top Psi Tools & Hardware - Others Experts
Marvin
Marvin
Tim Venetis
STEVE yes that one
Are you a Psi Tool and Hardware - Other Expert? Answer questions, earn points and help others
