SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If
this is the wrong model, your manual may be listed at this site as
well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
SOURCE: can i use shaving cream with a norelco electric
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
SOURCE: The shaving screen pops up when I turn on the
If the shaver heads pops up, this is because you have not cleaned it properly. This is common on this model type. You will need to thoroughly clean the top of the shaver body. Remove the cutters so that you can access it properly. You may need to use a toothpick or similar object to loosen and remove the build-up in the crevices. Then brush it all out with an old toothbrush or similar.
Clean it thoroughly and it will fix your problem
If you require a new screen for your shaver, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
SOURCE: I just received a Remington MS3-4700 Shaver and I
These shut off when not in use to conserve battery power
Testimonial: "Thanks for the prompt response in answering my question about the shaver LCD display."
