SOURCE: samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
SOURCE: no picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
SOURCE: had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
