Question about Samsung CLP 315 Laser Printer
Led light is solid orange and all toner lights are solid red was printing fine prior to this, now will not do anything
Posted by rnjmb on
chriswalk735
    New Friend:
Replace ALL cartridges - they are empty.
My Samsung does not warn me when levels are low - same problems occurs.
Replace cartridges and you'll be fine
Posted on Sep 12, 2011
My CLP315 WON'T PRINT - IT HAS THE ORANGE LED LIGHT ON. HAVE CHECKED THE PAPER LEVEL, WASTE TONER CARTRIDGE AND REBOOTED SEVERAL TIME BUT ORANGE LIGHT REMAINS ON
Dear Hamad
Pl. run the application SAMSUNG SMART PANEL or SAMSUNG EASY PRINTER MANAGER in pc. get a test print it will notice the exact error massage. You may also download the application from the link attached, by searching your model code.
Printer Support SAMSUNG India
Thanks.
Mar 24, 2015 | Samsung CLP 315 Laser Printer
If the orange light is on and remains on does that mean that the toner is out of ink and needs to be replaced?? When you press print it makes noise but won't print anything and then the orange light is on.
Per Samsungs website:
When the toner cartridge is near the end of its life:
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
My CLP315 WON'T PRINT - IT HAS THE RED LED LIGHT ON. HAVE CHECKED THE PAPER LEVEL, WASTE TONER CARTRIDGE NAD REBOOTED SEVERAL TIME BUT RED LIGHT REMAINS ON
The problems you checked are indicated by a blinking red light (it denotes minor errors). A solid red light usually means that one of the toners is exhausted. If you look in the task bar, there's a little blue S; double click on this to launch Smart Panel, our monitoring software. It will tell you the specific error message. If one of the toners is showing empty already, are you sure this wasn't a used model or possibly a display unit that people would have been printing on?
Nov 27, 2010 | Samsung SAM CLP315 COLOR LASER PRINTER
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Had it a while and it stopped working.
Come on copier tec you should know better, need to know which light is showing orange, Drum,toner,paper,status?
Intuition tells me that you have a orange toner light and a red status showing, and you are using a non OEM toner, but thats guessing.
Dec 26, 2007 | Brother HL 5140 Laser Printer
Samsung CLP 315 Laser Printer Logo
680 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
