SOURCE: Custom music for GTA L.C.S.
1) Download the Codemasters utility - ftp://downloads.codemasters.com/upgrade/Codemasters_EACSetup.zip
2) Make sure you have a game save for GTA on your PSP memory disk
3) Install the Codemasters utility on your PC
4) Connect the PSP to your PC in USB mode.
5) Goto the folder PSP and then SAVEDATA - look for the name of your GTA gamesave folder. For me it was ULES00151S0
6) Now you need to create a new folder in SAVEDATA that holds the custom soundtracks. Using the name of the game save folder remove the final S0 and add CUSTOMTRACKS - create a folder using this name. So for me my GTA music folder is called ULES00151CUSTOMTRACKS. Note that is a new folder - NOT the game folder renamed. For Vice City name the folder ULES00502CUSTOMTRACKS.
7) Fire up the Codemasters utility on the PC, select mp3’s from the hard disk or a music CD, select the custom tracks folder created above and convert your music.
Once converted, goto the custom tracks folder and rename all the files from *.toc to *.gta
9) Fire up GTA, select custom soundtrack in audio options and enjoy your own music.
SOURCE: downloaded games won't work
the items you downloaded is not compatible, the system file is not supported, you must go to the download station, and ask what is the better system for PSP
SOURCE: psp will hung up when playing Gta vice city stories
Are you playing the GTA Vice City Story from the Memory Stick or from the UMD.
If you are playing the GTA from the memory stick, I assume you have a customized firmware (CFW). Try to upgrade your firmware to higher version.
If you are playing the GTA from the UMD, update your PSP firmware.
check cheatcc.com for cheats
Search on www.torrpass.info.com
