I have a new panasonic cordless phone. It is connected with the comcast cable system. When talking on the phone the phone has a series of beeps and cuts me off. I have had the cable company come out three times , new lines were run and still the problem happens.i called yesterday and wasy told to diconnect and plug the phone into the regular jack. has anyone else ever complained of this beeping prpblem. I took of call waiting to see if that was the problem. it is very annoying and i have tried to fix it for three months
model number kx-tg1032 with two handsets
SOURCE: Dropped calls when cordless phone plugged into it.
I have solved this problem several times by using a splitter at the telephone jack instead of the XDP port on the phone. The extension is programmed to share the port isn't it? That is in program 600.
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: I have a panasonic KX-TG2336S
Just in case you don't have a manual
http://service.us.panasonic.com/OPERMANPDF/KXTG2336.PDF
Page 55 lists your trouble and gets you to page 49. You take the bandset and base, press the locator button on the base and then press the flash/recall button on the handset until Handset Registering appears on the display. If it beeps one time, wait 20 seconds and it should register. If it beeps 3 times, keep trying.
Carl
SOURCE: Openning a panasonic cordless phone handset
Carefully slide a thin bladed jewellers screw driver along the side of the case as you go the catches will release, do not force it !!
Good luck
SOURCE: I have a panasonic cordless phone, model
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
same issue with KXTG5633 cordless phone set. Beeping starts somewhat randomly and continues usually for est 8-10 times, sometimes the phone then works ok when it stops, sometimes not. Previous cordless phones have had similar problems. Very annoying.
