SOURCE: quad bike keeps cutting out
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There may be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
SOURCE: Jonway speedy 50cc moped....2 stroke or 4?
What year is it ? Is the cylinder-head height or shape capable of holding a rocker shaft and valve ?
SOURCE: wiring diagram for 50cc koala quad please
A service manual is a valuable tool with an aging bike. I suggest the dealer/mfr. or Clymer books. In the meantime, go to the library reference section...646 stacks should have what you need.
SOURCE: how do i derestrict my lifan s-ray 50cc 4-stroke
Unless you find a small "restricting washer" between the head and the exhaust pipe...Then usually there is no easy means. In the past these "washers" were put in place to reduce performance, the idea was as the riders skills improve the washer can be removed. It also was a way for parents to keep their children from zooming flat out everywhere.
SOURCE: will not run with battery
You have a generator fault or regulator fault. Book it into a garage and have it repaired.
