Question about Tomtom GO 910 GPS Receiver
TOMTOM ONE -ABOUT 5 YEARS OLD NOT SHOWING ON LIST OF DEVICE, DOES NOT USE A CARD. PROBLEM-CANNOT SWITCH IT ON. Help!!
Posted by paulinesim on
LP
  • Tomtom Master
  • 514 Answers
First, make sure your battery is fully charged. Then try to do a "Reset" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Posted on Oct 27, 2013
4 Related Answers
Anonymous
  • 4 Answers
SOURCE: SD Card not showing in my Tomtom go 720 to play MP3
If you want to play mp3 songs from sd card then create mp3 folder and place all the songs in side that folder. Now when you go to Juke box menu it will scan all the songs and you will be able to play them the way you want..
Posted on Mar 05, 2008
Anonymous
SOURCE: tomtom shows X and animation on a card going out from device
It is a oryginal card from tomtom one which i HAVE FROM NEW
Posted on Jun 18, 2009
Anonymous
  • 12 Answers
SOURCE: Tomtom Go920 device is not recognized by computer
I had this issue with my Go930 and inserted an SD card into the slot underneath and, hey presto, it now works. You dont have to use the SD card, but to get the Home2 software to recognise it, there must be one present the first time you "pair it" with this software. I can now use it without the card present
Posted on Feb 18, 2010
Anonymous
SOURCE: can u help my tomtom has a problem?
My TomTom 3rd g is acting up. It is not making a connection. The green bar run quickly and than the screen shows no hands / touch available. It will not go any further than that. It keeps running the same thing over and over again.
P.S. I tried resetting but it just shows that screen
Posted on Feb 20, 2010
Hi, I have tom tom one. Whenever I try to turn it on, it gets on but then it starts displaying the screen showing sd card coming out of the unit having red cross on the sd card. It keeps showing this pic....
Please follow the steps below to solve the issue. This is caused by an update. If you are not sure, how to do this, call TomTom help line for assistance.
STEP 1 - Find the mapsettings.cfg
- Connect your device to the computer and switch it on
- On your PC, click on My Computer to access your TomTom drive. On a Mac you can double click on it on your desktop
- Inside the TomTom drive, you will see a list of folders (on Windows these are yellow, on a Mac they are blue) as well as some loose files
- Please find the folder that is named as the map on your device i.e. United_Kingdom_and_Republic_of_Ireland_or_Western_Europe etc
- Double click on this folder to access it and please find the file called mapsettings.cfg
- Please delete this file
STEP 2 - Creating a manual backup of your map
- Right click on this folder and copy it
- Go to the desktop of your computer and paste the map folder
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your map.
STEP 3 - Format your TomTom device
IMPORTANT: ONLY continue if you were successful in making the back up of your device
For PC users:
- Open My Computer. Right click on the TomTom device drive and click 'Format'. Make sure Quick Format is not selected.
For Mac users:
- From the Finder menu, click 'Go' > 'Utilities', then double click 'Disk Utility'. In the 'Disk Utility', select the volume below the TomTom disk. Make sure the 'Format' is set to 'MS-DOS (FAT)' and click 'Erase'.
STEP 4 - Remove old files from your computer
- Open TomTom HOME
- Click on 'Manage my device'
- Click on the 'Items on computer' tab
- Tick the options for 'Applications' and 'Voices'
- Click on 'Remove items from computer'
STEP 5 - Install the software on your device
- Click on 'Update my device'
- Tick the options for 'Application' and at least one voice (eg, Jane)
- Please do NOT select your map at this stage.
- Click on 'Update and Install'
- Click 'Done'
Your navigation device starts and then connects to the computer again. HOME may offer more than one application update. Please repeat this step until no further application updates are offered.
STEP 6 - Restore the map
- Find the map you copied to your desktop and copy it again
- On your computer go to 'Start' -> 'My Computer' and open the TomTom drive
- Right click anywhere and select 'Paste'
STEP 7 - Check the Device
- Eject the drive (on Windows, go back to My Computer and right click on it and select Eject; on a Mac, drag the drive into the trash)
- Please disconnect your device and let it load up as normal
- You should now be able to set up the device as normal
Good Luck!
Jun 14, 2011 | Tomtom ONE GPS Receiver
Cant get updates
1) Format the Memory Card via Windows
2) Remove Card/Device from Computer
3) Plug Device/Card into Computer
4) Open up TOMTOM Home
5) It most likely will not recognise the Card/Device as a TOMTOM but will update it to a previous firmware. Keep following On-Screen prompts until fully updated.
6) Unplug your Card/Device, turn on and enjoy :)
Hope this helps!
Apr 26, 2010 | Tomtom ONE 3rd Edition GPS
Can u help my tomtom has a problem?
Feb 10, 2010 | Tomtom ONE 3rd Edition GPS
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Can not use computer voices on my tomtom 520t
On your device you may have a corrupt file that is causing the noise distortion when you use the computer voices. The solution to this is to completely remove the software from your device and reinstall it again as described in the steps below. Please ensure that you have the latest TomTom Home software installed on your computer:-
You can download and install the latest version of TomTom HOME from the following link:
http://www.tomtom.com/home
Once you have the latest version of TomTom Home installed, please follow these steps:-
STEP 1. Creating a Manual backup of your TomTom
• Charge your unit for at least two hours (preferably via the home charger)
• Perform a reset on your device (see: http://www.tomtom.com/6965 )
If you have not made a backup yet you can do so by making a manual backup of your TomTom. To do this, please look at the following web page:-
http://www.tomtom.com/3171#backup
• Connect your TomTom to the computer
• Open My Computer, you should see the TomTom as a removable drive, double click into it. (on a mac you will see the TomTom as a disk drive on your desktop)
• You will see a list of files and folders.
• Copy all of the folders on the TomTom, one by one to the backup folder. DO NOT copy the 'Loquendo' folder.
• This can take up to 1 hour to complete depending on the device.
• If you get any error messages while copying, move on to the next folder and copy that to the backup folder.
• If possible, please make a note of any error message that occur while copying the folders, and make a note of which folder causes the error message.
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in step 1. If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2. Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom icon (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Do a full format by selecting FAT 32 and click on Start, do not select 'quick format'. The TomTom is now formatted.
• Disconnect the TomTom from the computer and switch it on. It will load up with a red cross on the screen.
• Reset the TomTom with a paperclip in the reset hole for 30 seconds, see http://www.tomtom.com/6965 in how to do this.
• Once Reset, switch the TomTom off, disconnect it from the computer and then switch it back on again, it will still show a red cross on the screen.
STEP 3. Restore the Folders to the TomTom
• Connect your TomTom back to the computer and make sure it is switched on
• Go to your backup folder on your desktop, double left click into it. You will see all of your backup folders.
• Copy the folders one by one to the TomTom by right clicking on the folder, select copy then open My Computer, double left click onto the TomTom drive and choose paste.
• Turn the device off (with the on/off switch) and disconnect it from the computer.
• Switch the TomTom back on.
STEP 4. Update your device
• Open TomTom Home
• Connect your device to the PC
• A list of updates should appear, if not, click on Update my Go
• Select only the program application update.
• Click on Update and Install.
• Once Installed, open TomTom Home
• Click on 'Device -> Disconnect Device'.
• Switch your TomTom On to complete the installation.
The Application is now installed, and your TomTom should now be working.
STEP 5. Run the Clear Flash Tool
• Close TomTom Home. (on a PC, make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen by the computer clock)
• Download and run the clear flash tool from : http://www.tomtom.com/updates/clear_flash/clear_flash.exe Make sure your TomTom is connected to the computer and switched on when you do this.
STEP 6. Install a computer voice
• Open TomTom Home
• Click on 'Add maps, traffic and voices -> computer voices
• select the voice of Kate and install it.
The Computer voice is now installed, and your TomTom should now be working.
Dec 06, 2008 | Tomtom GO 910 GPS Receiver
My 720 frozen
This solution can be used in the following situations:
• The device hangs in the start screen (splash screen )
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
Nov 19, 2008 | Tomtom GO 720 GPS Receiver
Tomtom go730t, switch on and get start up screen then displays "no maps found".
Make sure that you have the map installed first of all, or you have the SD card inserted correctly (if using one).
If that is OK, try resetting the device. To reset your TomTom device, do the following:
  1. Charge your TomTom
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. The reset button is located on the underside of the device.
Should that still not help, try to download and install the map from TomTom website. Instructions HERE
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 25, 2008 | Tomtom GPS
Tomtom one xl freezing on start up screen
OK... I found an amature solution;
- Do a soft reset of the system, with the paperclip (see tomtom site)
- Put the device on the docking station and connect it to power as well as to your computer. While it's turned off
- Turn on the TOMTOM while connected to the computer
- Start the TOMTOM Home software
- And it made connection again
- Disconnect the device via the software
- Take the device out of the docking station
- Turn it off and on once
This worked for me, my next step would have been the support desk. Grtz Derk
Sep 28, 2008 | Tomtom ONE GPS Receiver
TomTom Go300
If you follow the instructions on the Tom Tom support site - It states
1) First download TomTom HOME version 1
it will update the boot code on the card
2) Install TomTom Home Version 2
Aug 25, 2008 | Tomtom GO 300 GPS Receiver
Unable to Upgrade SD Card
you have to make sure it is formated to FAT not FAT32
go to www.tomtom.com
click on support...
Dec 17, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 910 GPS Receiver Logo
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
