SOURCE: Jamming, roller lines and loud fan
You'll want to purchase the service manual for this printer if you do not already have one. Obviously the fan is the most annoying problem. But the jamming, the roller marks, and other issues would indicate that the entire printer is probably needing to be cleaned out and that the rollers may even need to be reconditioned or replaced.
SOURCE: VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
SOURCE: Samsung ML-2571N Laser Printer - paper jammed around roller
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=monochromelaserprinters&model_cd=ML-2571N/XAA&mode=C
this link will guide you to the site with the user guides...but in short ..all ya have to do is to be careful and to open and remove the paper...there are not many things that may be damaged in the process...but there is a certain order you have to follow in doing it ...and a few devices that has unusual safety removing gadgets...
SOURCE: Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
