Hitachi 43UWX10B 43" Rear Projection Television Logo
Question about Hitachi 43UWX10B 43" Rear Projection Television
Horizontal POS... I got into that menu you mentioned and it is large...just not sure which item needs to be changed... As far as the company you used, where are you located? I'm in DFW. I know that this is the same issue I am having, but just want to get out on the cheap. :) Go ahead and give me that business info... thanks again!!! Daniel
Posted by Daniel Sorrels on
1 Related Answer
Anonymous
SOURCE: your hitachi tv problem....
Sorry I can not help. I had to work that day. My wife was home and she told me he went into some kind of service or maintenance menu on the TV by pressing some button combination. Again, sorry I can not help you. I can give you the information of the company if you want to call them.
Posted on Sep 11, 2008
2answers
How can I change language for a clarion NX 309 from Japanese to Engligh?
I hear ya. I would use Google Translate with my smartphone camera to try to decode the Japanese, far enough to get to a language menu, where you can select English as the language.
Have Easy Share C183 cannot change from Spanish to English
Press the MENU button to bring up the menu, use cursor-left/right to select the Setting tab (three horizontal sliders), then select the sixth item on the menu.
Oct 03, 2013 • Cameras
I need to change language to english
In any mode, press the MENU button. Use cursor-up/down to highlight SETUP (three horizontal sliders) and press the OK button. Use cursor-up/down to highlight the ninth item and press OK.
1helpful
Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the...
\http://www.retrevo.com/support/Dynex-DX-LTDVD22-TVs-manual/id/23122dj497/t/2/
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
The restaurant i'm working for is changing to pc-america's cre pos. the old pos prints the food orders and table #'s in a large font on the kitchen printer. i am looking for a way to configure cre's...
As far as I know, there is no way to change the font settings in CRE (I hope you mean RPE). But, you may be able to change the default settings in the printer itself to get larger print. I am available for tech help if you need it, but you should have 3 months free support from PCAmerica with the purchase. I also do custom menu support for RPE. [email protected]
2answers
Horizontal view on screen will not re-center
You want to locate Position or Horiz Position from the Menu screen. Press menu first then Up or Down to select the item you want then Left or Right, I can't be more specific as all monitors are different - but there isn't a single button to center. You could also try the different input settings (Analog, Digital, etc) if the Autoselect isn't working properly.
3answers
Going from one POS system to another
If you are having communication problems with the port on the computer then this can solve it. make sure your pos system is not running or any other background services that monitor the port. Then go into your device manager and go to the properties page for that com port (COM2 for example), hit the device settings tab and change the data bits setting to 7 rather than 8, if this number is different than 8 which is default, just remember what it was in case you need to revert the setting. good luck
Your hitachi tv problem....
1helpful
Sony K60XBR800
Model
KF50XBR800, KF60DX100, KF60XBR800
RESOLUTION
Yes. Try the attached procedure. This has proven to be very effective.
Enter the service mode by pressing Display, 5, Vol +, Power.
Press Menu and go to Setup. Select Image Revision and set to 1. Press Menu once to exit the menu screen.
Cycle thru the service mode using button 5 until you get to D-GM TG. Press number 1 on remote once. You should now be at the 1 POS CTL. Change data from 11->1.
Push the number 1 button on the remote 14 times until you are at 15 ENB POS. Change data from 5->23.
Push number 1 button on the remote 8 times until you are on item number 23 PRG POS. Change data from 0->2. Write the data to memory by pressing MUTE, ENTER.
Push number 2 on remote 6 times until you are at H POS SHIFT. Proceed with the following steps very carefully. 0 VAR POS-CTL=0. Press number 1 on remote. Change D-GM HP item 1 from 9->11. Write the data to memory by pressing MUTE, ENTER.
Press 4 on remote. Change to 0 VAR POS-CTL=1. Then press #1 on remote. D-GM HP ITEM #1. Change data from 9->11. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=2. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=3. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=4. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=5. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=6. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=7. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=8. Then press #1 on remote. D-GM HP ITEM #1. Change data from 5->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=9. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=10. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=11. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=12. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=13. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=14. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=15. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data.
Press #5 on remote 6 times back to catagory D-GM TG INV CTL. Press number 1 on remote once to the Catagory D-GM TG 1 POS CTL. Change the data value to find the best setting where no double images, ghosts nor merged colors appears. WRITE DATA.
Press #2 on the remote 11 times to the Option-E O Lamp Time. Note the current value and write it down. Add 2000 to the value (ex if 1356, than 1356+2000= 3356). Divide this number by 100 and write this value to the Option-E 11 P CTL SHT1. For our example above we would have 3356/100= 33.56. So we can round to 34.
Now add 50 to this number. In our example we would have 34+50=84. Write this value to the Option-E 12 P CTL SHT2. Make sure to write the data.
Select AUTO in the menu for the Image Revision setting and exit the menu screen. Confirm that the picture is fine.
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
