Jenn-Air JGC8430 Gas Cooktop Logo
Question about Jenn-Air JGC8430 Gas Cooktop
One of the burner does not ignite wher to get the parts to fix it?
Posted by starlitegrap on
espressonist
  • Jenn-Air Master
  • 1,711 Answers
We have here the parts diagrams and parts lists and also is an online shop and you can buy all the parts you need. Just clik on the excact model.
Posted on Sep 07, 2011
Ingiter will either fail to start burner or won't quit clicking on the 1% of the times it does start up the burner
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
One of the burners ignition will not turn off - it continually is sparking - i have to turn off the elec supply to stop the ignition ? any ideas
Hi and welcome to FixYa, I am Kelly. On the burner your having problems with the ignition control switch located in front of the gas control vale on the stem has failed. These are cheesy little switches that are thin ceramic with nothing but 2 strips of copper inside them. One piece is fixed and the other piece is movable by the ceramic switch cam. If the movable copper arm or fixed copper strip gets bent the ignition will not shut off. Also if the ceramic cam of the switch fractures it will cause the switch to stay actuated. The gas valve has to be disconnected and removed to change the switch on most units. The wires in the switch have to be unlocked by inserting a jewelers screwdriver into the holes in the switch body to release the wires. These switches are common to most every gas cook top models no matter the brand. Without your model number I can not provide you with the manufacturers replacement part number. Change the burner ignition switch on the front of the gas valve for the burner with the problem and it will work fine.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 • Cooktops
When one burner knob is turned to ignite all four burners turn on.
What do you mean by "all four burners turn on"
Some electronic ignite systems turn on on all the burners, But just the SPARK not the gas part of the burner.
Is this what you are describing?.
5helpful
Clicks but does not does not igite
Hello, thank you for your post. It sound like your saying the burners are not lighting up. Most of the time this is just a simple fix. Next time you turn on your burner notice were the igniter sparks this part of the burner needed to be cleaned. You should be able to take the burner cap off and the burner use a wire brush to clean the surface area so the spark has good contact. Take notice also of the igniter you will need to change it out if you see any cracks around the ceramic housing.
Happy Holidays! Please rate me "4 thumbs" if this information was useful.
3helpful
One burner will not light other burner clicks
Under the burners where you have the gas pipes and valves
you have only one electrical part the ignite spark module. This plastic box has
one input the power wire and for outputs one for each burner. Now you can check
if the wire going to the problematic burner is loose or cut out and fix it. If
all wires look ok then the Spark device is bad and need a new one.
2answers
Miele LP cooktop: we turned the power to the range off. when we turned on again it didn't ignite (it has power!)
Hello
Keep the air holes around the burners free of debris and grease by clearing out the holes with a thin piece of wire or a toothpick. Cleaning out the holes helps the ignitor light the cooktop
Listen for the clicking sound of the ignitor, then turn off the burner if you don't hear the clicking.
Turn the burner to the "Off" position, if you continue to hear the ignitor tick after you've lit the burner. Turn the burner back on to relight it. Ignitors normally make a brief series of electrical clicking sounds when you turn on the ignitors.
Let the ceramic igniter dry out if it has gotten wet and the burner won't ignite. If the igniter isn't wet, clear out the little holes in the burner by chipping out any blockage with a straightened paper clip.
Clean the electrodes if the burners still don't light. The electrode is in the burner base. Clean the metal part with a soft cloth. You can use emery board on the metal part but not the white ceramic part.
One burner igniter fails to spark after getting wet
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
1helpful
2answers
Clicking
In addition to polishing up the end of the igniter as mentioned above, remove the burner cap cover and and the round burner cap. As noted above, electrical contact or grounding is an important element in the spark igniter function. Any poor contact surface can cause the igniters to continue to spark after a burner lites. If everything seems in order, polish the underside of the aluminum burner cap and the top side of the aluminum burner base (where they come in contact with each other). This is part of the grounding circuit for the igniters. I used an "SOS" pad. In our case, these parts had tarnished with age. My wife was very happy when I fixed this one.
Top Jenn-Air Cooktops Experts
Marvin
Marvin
David Shaub
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
