Sounds like some article of clothing got between the door glass and door boot and pulled the rubber door boot away from the front of the washer. Check and make sure the rubber boot is not torn. If it is ok you should be able to slip the lip of the door boot back onto the front of the washer, make sure you get it in the grove. Then put the wire retainer back around the boot, you may need an extra hand or two to hold it and stretch the spring back on. Hope this helps
Hello Ann Calk -Unfortunately depending on which part it is exactly since there is any adhesive available to glue it back together you need to purchase the entire door panel. I would suggest contacting a professional to accurately diagnose and repair the window washer.
