Question about Lanier 1205 Copier
Hi have a lanier copier model 6725. When I make copies it makes the copy and then also prints grey across the entire copy. Looks like it is printing old ghost copies...how can I fix this
Posted by bookdeeva on
santosj27
  • 263 Answers
Hello!
If you say that you see old ghodt copies the problem is with the Fuser Roller in the Fusing Unit.
If this is right i advise you to call a Tech (if you do not have the skills to change it)
See you!
Posted on Sep 02, 2011
We have a Lanier 5618 copier. Toner must have spilled out and the copies are coming our covered with thick black lines on the entire page. How do we open the machine to clean it?
first you have to see if it happens when they get to a copy or a print. If it happens in print there is not much to clean, you have to replace worn parts. If it happens only on the copy you have mirrors Sanner dirty. (strip the screws and lifting the glass carefully cleaned the mirrors).
Hope this has helped
Jan 20, 2011 | Lanier Office Equipment & Supplies
I have a black line on my copies. i have a lanier 7320 copier. Is it my drum?
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Jan 18, 2011 | Lanier 1205 Copier
Lanier ld 435 color print code sc548
re install fixing unit and do the sc reset. press clear mode 2x 107 press clear/stop until COPY SP appears press Copy Sp then exit, turn off machine then on after 5 to 10 seconds
Aug 23, 2010 | Lanier Office Equipment & Supplies
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Toshiba eStudio 210c grey background on copies
U need to check your developer material. How many copiers has been made?
U can also perform 05-200 for the auto toner adjustment. The value should be in the range of 235-245% ( 2.35v - 2.45v )
Mar 26, 2009 | Toshiba e-Studio 232 Black and White...
LANIER COPIER 7313
I guess by your fault description that there is a blank gap before the printing starts? The only way to cure this problem is to replace the registration clutch as it is turning on too late and not releasing the paper quick enough. Also check that the paper tray dial is displaying the correct paper size and position.
Thanks Jason
Aug 15, 2008 | Office Equipment & Supplies
Unable to print more than 3 copies of anything
What error if any do you get? Sounds like your printer needs a firmware update.
Carl ( Lanier tech )
Oct 24, 2006 | Lanier 5222/27 Laser Printer
135 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
