It sounds like you have blown fuse to the Alternator.. I don't know what car you are talking about but they charging systems vary.. But if alternator isn't getting all the power it needs it won't charge. this should be checked.
good luck
Phillip is correct - Once you have the car started and running the alternator can supply enough power to run the car - however you need some power at the Alternator first to "excite" the system so it will start charging and keep the car running.
It may be blown fuse or faulty wiring - at this stage the battery and alternator don't appear to be the problem.
If you can't fix the problem yourself take it to an Auto Electrical Specialist and save a lot of heartache.
Get ecu checked with diagnostic machine will cost roughly £60- £100 but will prob help
Car will keep running as long as it's hooked up but dies shorty after can't find the problem I've had it checked neither the batterie or alternator were bad so I had the whole system gone through and still can't find anything need help if you think you know what it is then plz answer
