Question about Texas Instruments TI-86 Calculator
My TI-86 screen had white lines (dead pixels) in the first and last rows. By following k_akima's remedy (set it to darkest and leave it for a while), I managed to get back the first row pixels to normal. The last row is still partially dead. Do you guys know any other solution to this?
Posted by vera_gabor on
k24674
  • Texas Instru... Master
  • 8,091 Answers
There is no solution for old age. Get a newer calculator.
Posted on May 28, 2018
5 Related Answers
Anonymous
SOURCE: TI-82 Screen Not Working or Black
Try a hard reset. Take out all the batteries, and while putting them back in, hold down the "DEL" key. Then, turn it back on and you can adjust the contrast by pressing the "2nd" key and the down arrow at the same time. I just got this info. online and it finally worked for me...good luck!
Posted on Apr 03, 2008
k24674
  • 8091 Answers
SOURCE: buttons on far right row of ti-84 plus clear the screen
It seems like a harware problem. I think you shoul have the calculator repaired.
Hope it helps.
Posted on Sep 10, 2009
raklein62
Richard Klein
  • 360 Answers
SOURCE: TI-89
If you make a custom, you can have the Toolbar F function keys operate as 7, 8, & 9. If you respond with a rating I'd even write one out for you, and make it where you just hit [2nd] [CUSTOM] for the use of those keys.
Posted on Sep 15, 2009
Jay Renner
  • 5 Answers
SOURCE: texas instruments ti-86 screen problem
The TI-86 uses a very small, very thin ribbon cable to connect the display board to the LCD. The cable is about 2.5 " wide and about 4" long, and is only slightly thicker than a piece of paper but has about 40+ leads buried inside. Over time the leads will break at the folds (there are at least two folds in this cable to fit it down inside the case). There is no cheap solution to fix this problem. You might have some "Mr. Fix-it" try to fix it, but he will tell you to throw it away after he renders it completely inoperable. The calculator uses two Torx bit screws at the bottom of the case (T-6 size) so you will have to get the correct screwdriver to open the case. Save your money, sanity and time and use it till you can't stand the missing lines and throw it out. Even the data cable looks like it is glued down so if it lifts off after being cooked or frozen a couple of dozen times in the back of your car you can't fix this.
Posted on Jan 20, 2010
k24674
  • 8091 Answers
SOURCE: I need to enter a 3 x 3 matrix.
  1. Press [2nd] [X to -1] under [MATH[ to access the (Matrix) menus.
  2. Use right arrow to highlight [EDIT]
  3. Press [1:A] to edit (create from scratch) the A matrix.
  4. On the line MATRIX[A] line cursor blinks on 1
  5. Enter m dimension (3) and press [ENTER].
  6. Cursor moves to the second dimension (n). type 3.
  7. Press [ENTER].
  8. A 3x3 matrix template is displayed with A_11 element highlighted.
  9. Replace the value 0 with your value for A_11.
  10. Press [ENTER].
  11. Type a value and press [ENTER].
  12. When finished, press [2nd][QUIT] to exit the matrix editor.
Your matrix is ready to be operated on (squaring, multiplication by a scalar, inverse if matrix is non-singular, determinant.) All operations are available under [2nd][X^-1](Matrix) [=>][MATH].
Posted on Feb 03, 2010
Testimonial: "Thank you! This was a great help. You took me step by step through the process. It was a great help. Melisse"
White line down centre of screen advent verona
Those are called "stuck pixels" .
Try this:
1.Turn off your laptop.
2.Get yourself a damp cloth, so that you won't scratch the screen.
3.Apply pressure to the area where the stuck pixel is. Try not to put pressure anywhere else, as this may trigger the creation of more stuck pixels.
4.While applying pressure, turn on your Laptop.
5.Remove pressure and the stuck pixel should be gone.
If the computer is still under warranty, return it for repair. If the warranty is dead, you may wish to try some of the home remedies listed in this article:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Aug 02, 2011 | Computers & Internet
Blank lines across the screen of a TI-86 graphing calculator
Try this, hook up new battery and go to MODE and darken and lighten the screen.. do it ten to fifteen times. if that doesn't help, try hook up most left and most right's battery terminal to a DC supply at 4.5V. dont go above 4.5 it will fry your calc (it is design to handle 3V). now you are forcing extra juice into the dead LCD screen lines... and reapeat the MODE + darken trick. I fixed mine like that! Works! and remeber to leave it completely black(darkest) for a while to keep that dead line alive!
Jul 06, 2009 | Texas Instruments TI-86 Calculator
Texas instruments ti-86 screen problem
Mar 28, 2008 | Texas Instruments TI-86 Calculator
Jan 10, 2008 | Texas Instruments TI-82 Calculator
Jumbled Numbers/Pixels
I had the same problem but i finally found the solution i held my calculator at gun point and told it to stop messing with me.
Nov 11, 2007 | Texas Instruments TI-83 Plus Calculator
Ti 86
Hi I got a problem with Ti-86 which is a line of the screen pixel missing. I tried to increase and decrease the intensity of the screen (2nd and up, down). Also tried to go to MODE function. I have tried those for several times. It works great. The line of those missing screen pixel came back. I don't know why. Just try it.
Sep 12, 2007 | Texas Instruments TI-86 Calculator
TI-83 LCD Screen Problem
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem.
Aug 14, 2007 | Texas Instruments TI-83 Plus Calculator
Calculator screen stratified black lines
call the tech support # 972 644 5580, they man was very helpful and they walk you through troubleshooting
Jan 19, 2007 | Texas Instruments TI-86 Calculator
Random characters lines and pixels
I've had a similar problem in the past with my TI-86. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons every few minutes.) It works great, and the calculator is fine unless you leave it unused for a month or so. A similar solution may work for you.
Dec 12, 2006 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-86 Calculator Logo
801 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
