Hey, it souds like your micro SD card has been damaged or corrupted so that your computer cannot recognize it. Well, what you need is a recovery tool. You can try 4Card Recovery, which is a professional recovery tool and easy to deal with data loss problem.
Here are the detailed steps of using 4 Card Recovery:
step one, download 4card recovery software and install it on your computer
Step two, run it and select the files that you want to recover
Step three, scan your files and wait for about 10 minutes
Step four, put your recovered files on other part
See, quite simple.
As long as your data has not changed, it will help all your files.
Have a try.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Micro SD card can not open or connect with computer? Try 4Card Recovery software. It can easily deal with these problem, especially data loss case. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
The first thing you need to do is to recover your data. Why not try 4Card Recovery. It is specialize in solving this kind of situation, which can recover films, photos, and other files. As long as your data still there and not changed, it can help you recover all of them. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
SOURCE: inserting a 2gb micro sd mem card in lg webslider to have xtr spa
You have to move each song/file to your external memory straight away after recieving it via bluetooth because it goes straight onto your phone memory. Seach your phone memory and move all photos, videos, music etc to ext.memory by selecting the file-select options in lefthand corner- move to external memory. If your phone cannot find your external memory then you havent formatted your memory card. Go to Settings-Memory Status(way way down the bottom of list)-External Memory-Format(lefthand corner). Just remember to move each file to ext. mem. straight away.Its a pain but you have to do it manually, the phone doesnt do it for you.
SOURCE: We just bought a 4gb micro sd card with sd adapter
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
SOURCE: my mobile memory card has been locked i want to
cannot read for psp memory stick pro duo 4gb
SOURCE: i cannot access my 2GB
i
cannot access my 2GB micro sd card in computer or phone, when i opened
it from computer i get message card need to be formated but when i
start to format card windows says unable to format this device. please
help me.
from kapil sharma
