I know this isn't your exact motherboard, but this may help you in some way. Just to make sure the jumpers are set up correctly for the front panel audio. Click HERE and go to page 11 to see the jumper settings. You can also try to do a "Scan for hardware changes" in Device Manager. From what you have written, it seems to me that it's something to do with the audio in the bios, yet you say it's enabled. If this is a problem after installing a new program or operating system, it could be that the new software is to blame.
I hope this helps. let me know if there is anything I can do to help you further
Joe
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
