Hey friend, you can try this one.
Leading cause of paper
jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
jams is debris / foreign objects that accidentally fell into the paper feed
1. Remove
the sheets of paper from the feeder.
2. Grab a
flashlight and look inside the feeder for any debris or foreign objects.
3. If
you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4. If
feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges.
5. Check
the cartridge area for any obstructions/debris in the cartridge carrier's path
or the paper path.
6. If
cartridge area is clear, close the cover.
7. Re-brick
your printer. Pull out the power supply, black box where the power cord is
plugged in at the back of the printer, and put it back after 30 seconds.
8. When
the printer turns on, reinsert the cartridges and load some paper. Try to print
a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem:
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
(pull out power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds).
8. When the
again.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
